- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq's cofixpoint productivity checker
- Date: Wed, 20 Aug 2014 11:35:52 -0400
Corecursive calls aren't allowed to appear nested inside anything but constructors and [match]es. Function application is never allowed, when reduction can't make it go away, which is the case here. Sorry!
On 08/20/2014 11:31 AM, Jason Gross wrote:
Why does Coq not notice that the following definition is manifestly productive?
Require Import Coq.Lists.Streams.
Fixpoint stream_prepend_list {T} (ls : list T) (rest : Stream T) : Stream T :=
match ls with
| nil => rest
| cons x xs => Cons x (stream_prepend_list xs rest)
end.
CoFixpoint flatten_stream {T} (s : Stream (T * list T)) : Stream T :=
match s with
| Cons x xs => Cons (fst x) (stream_prepend_list (snd x) (flatten_stream xs))
end.
It seems that Coq doesn't want me to put anything between the recursive call and the constructor, but it's syntactically obvious that my definition is productive...
- [Coq-Club] Coq's cofixpoint productivity checker, Jason Gross, 08/20/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker, Adam Chlipala, 08/20/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker, Maxime Dénès, 08/20/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker, Daniel Schepler, 08/20/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker, Jonathan, 08/22/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach, Andrei Popescu, 08/22/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach, Andreas Abel, 08/25/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach, Andrei Popescu, 08/25/2014
