coq-club - Re: [Coq-Club] Coq's cofixpoint productivity checker
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Coq's cofixpoint productivity checker
  • Date: Wed, 20 Aug 2014 10:21:49 -0700
As a follow-up to this, here's an example of how you could write an
equivalent definition that's accepted (where if s is generated using
state type S, prepend_list_and_flatten_stream ls s is generated using
state type list T * S):
Require Import Streams.
CoFixpoint prepend_list_and_flatten_stream {T}
(ls : list T) (s : Stream (T * list T)) : Stream T :=
match ls with
| nil => match s with
| Cons (x, xs) s' => Cons x (prepend_list_and_flatten_stream xs s')
end
| cons x xs => Cons x (prepend_list_and_flatten_stream xs s)
end.
Definition flatten_stream {T} (s : Stream (T * list T)) : Stream T :=
match s with
end.
Fixpoint stream_prepend_list {T} (ls : list T) (rest : Stream T) : Stream T :=
match ls with
| nil => rest
| cons x xs => Cons x (stream_prepend_list xs rest)
end.
Lemma stream_decomp : forall {T} (s : Stream T),
s = Cons (hd s) (tl s).
Proof.
destruct s; reflexivity.
Qed.
Lemma prepend_list_and_flatten_stream_eqn :
forall {T} (ls : list T) (s : Stream (T * list T)),
prepend_list_and_flatten_stream ls s =
stream_prepend_list ls (flatten_stream s).
Proof.
induction ls; simpl.
+ destruct s as [[x xs] s']; simpl.
match goal with |- ?LHS = _ => rewrite (stream_decomp LHS) end.
simpl. reflexivity.
+ intros.
simpl. f_equal; auto.
Qed.
Lemma flatten_stream_step : forall T (x : T) (xs : list T)
(s' : Stream (T * list T)),
flatten_stream (Cons (x, xs) s') =
Cons x (stream_prepend_list xs (flatten_stream s')).
Proof.
intros; simpl.
f_equal.
apply prepend_list_and_flatten_stream_eqn.
Qed.
Daniel Schepler
On Wed, Aug 20, 2014 at 10:00 AM, Daniel Schepler
<dschepler AT gmail.com>
wrote:
> I tend to find it helpful to think of Stream T as essentially covered by
> Definition state_iterator {S T:Type} (f : S -> T * S) : S -> Stream T :=
> cofix F (s:S) :=
> let (x, s') := f s in Cons x (F s').
> So basically, in order for a CoFixpoint definition to be accepted, it
> has to be easy to translate it into an iterated stream of this type,
> using a fairly simple state variable. (Of course, the translation
> becomes a bit more complex when it comes to things like stream_map2 :
> forall T1 T2 T3:Type, (T1 -> T2 -> T3) -> Stream T1 -> Stream T2 ->
> Stream T3, as you'd have to "take apart" the Stream T1 and Stream T2
> inputs to get their state types, and then take the product. So this
> heuristic needs to be taken with a grain of salt.)
> Daniel Schepler
> On Wed, Aug 20, 2014 at 8:31 AM, Jason Gross
> <jasongross9 AT gmail.com>
> wrote:
>> Hi,
>> Why does Coq not notice that the following definition is manifestly
>> productive?
>> Require Import Coq.Lists.Streams.
>> match ls with
>> | nil => rest
>> end.
>> CoFixpoint flatten_stream {T} (s : Stream (T * list T)) : Stream T :=
>> match s with
>> | Cons x xs => Cons (fst x) (stream_prepend_list (snd x)
>> (flatten_stream
>> xs))
>> end.
>> (* Error:
>> Recursive definition of flatten_stream is ill-formed.
>> In environment
>> flatten_stream : forall T : Type, Stream (T * list T) -> Stream T
>> T : Type
>> x : T * list T
>> xs : Stream (T * list T)
>> Sub-expression "stream_prepend_list (snd x) (flatten_stream T xs)" not in
>> guarded form (should be a constructor, an abstraction, a match, a cofix or
>> a
>> recursive call).
>> Recursive definition is:
>> "fun (T : Type) (s : Stream (T * list T)) =>
>> match s with
>> | Cons x xs =>
>> Cons (fst x) (stream_prepend_list (snd x) (flatten_stream T xs))
>> end". *)
>> It seems that Coq doesn't want me to put anything between the recursive
>> call
>> and the constructor, but it's syntactically obvious that my definition is
>> productive...
>> -Jason
