- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] an evar with a split personality
- Date: Thu, 4 Sep 2014 15:20:24 +0200
The reason why is looks weird is because you are misunderstanding what existential var instances are: they are not the context of the existential variable, but an explicit substitution which must be applied when the existential variable takes a value.
In your case, [rewrite aeqb] makes it so that every [a] in the [?9] of the conclusion must be replaced by [b]. Which is what happens. It may be confusing because both [a] and [b] are variable, but they need not be:
Goal forall a b:nat, a=2*b+a -> exists c:nat, c = c.
intros a b aeqb.
eexists. (*make an evar*)
match goal with |- ?V = ?V => remember V as e eqn:Q end. (*clone the evar*)
rewrite Q at 2. (*make the consequent and Q look really similar*)
rewrite aeqb. (* e = ?9 (* [2 * b + a, b, aeqb] *) *)
instantiate (1:=a). (* e=2*b+a *)
intros a b aeqb.
On 4 September 2014 03:19, Jonathan <jonikelee AT gmail.com> wrote:
When experimenting with the evars, using a recent trunk version of Coq, I noticed the following:
Set Printing Existential Instances. (*Or, if in CoqIde, use View->Display existential variable instances*)
Require Setoid.
Goal forall a b:nat, a=b -> exists c:nat, c = c.
intros a b aeqb.
rewrite aeqb. (*rewrite works! And the two evar contexts for the same "e" evar no longer match!*)
Fail exact Q. (*?*)
instantiate (1:=a) in Q. (*??*)
I don't know if this is a bug or a feature. I guess it could be a feature, but then it points out something quite unexpected: that a single evar can have multiple different contexts, even within the same goal. I was under the impression that all copies of the same evar shared the same single context.
If this is a bug - is the bug that "rewrite aeqb" does anything at all, or that it only rewrites one of the contexts?
If this is a feature:
Are all instances of an evar separable this way, or just some? Which ones?
What tactics other than rewrite can be used to modify a specific version of an evar's context without modifying the others? How does one target the context with a tactic?
-- Jonathan
- [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Matthieu Sozeau, 09/12/2014
