- To: hugoccomp AT gmail.com
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Induction with "eqn:" is broken?
- Date: Sun, 7 Sep 2014 16:53:50 +0200
Hi,
As it is implemented now, the "eqn:" modifier to induction is actually
pointless as it impacts the induction hypotheses in a way which makes
them useless. It is here by analogy with the "eqn:" for destruct, but
it is a posteriori an error to make it available for induction.
In any case, the primary use of the "eqn:" modifier was to remember
the value of the term destruct is applied on. If it also helps to
indicate which case of a case analysis proof is under consideration,
it is somehow incidental. Maybe one day will this information be made
available to the user without impacting the purely logical content of
the proof...
Hugo Herbelin
On Fri, Sep 05, 2014 at 02:50:13PM +0200,
wrote:
> A friend of mine is working his way through Software Foundations and was
> using
> its "Case" (and "SCase", etc) tactics to annotate the proof context.
> Eventually the book introduced the "eqn:" extra option to the "destruct"
> tactic, and it seemed like it was a a suitable replacement for that usage of
> "Case" tatics, until he tried to use the same option with "induction".
> Goal forall n, n+0=n.
> induction n as [|n'] eqn:Heqn.
> (*The first goal, 0+0=0, goes through normally...*)
> reflexivity.
> (*But here we are stuck - the equality generated by eqn: blocks usage of the
> inductive hypothesis. *)
> Is this behavior intended?
> A similar "impossible" proof state is reached if,
> instead of "induction n as [|n'] eqn:Heqn.", you start with "intro
> n;remember
> n;induction n".
> But if you're using "remember", you can "generalize dependent" the fresh
> term
> before the induction
> and then all goes through fine. I can't help but think that maybe "eqn:"
> should be doing something similar behind the scenes.
> Also i'm using Coq 8.4pl2 - if this is fixed on the later versions let me
> know.
- [Coq-Club] Induction with "eqn:" is broken?, hugoccomp, 09/05/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Hugo Herbelin, 09/07/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/07/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/23/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Hugo Carvalho, 09/24/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/24/2014
