coq-club - Re: [Coq-Club] Induction with "eqn:" is broken?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Induction with "eqn:" is broken?
  • Date: Tue, 23 Sep 2014 17:38:28 -0400
On 09/07/2014 10:53 AM, Hugo Herbelin wrote:
Hi,
As it is implemented now, the "eqn:" modifier to induction is actually
pointless as it impacts the induction hypotheses in a way which makes
them useless. It is here by analogy with the "eqn:" for destruct, but
it is a posteriori an error to make it available for induction.
I think I have a case of this, but it is slightly different.  The eqn: is modifying a destruct prior to the induction (case_eq ; intros works similarly), but the induction hypotheses are still messed up as a result.  Here's a simplified example:
Variable P : Prop.
Inductive foo : Type :=
| Foo (l : list nat) : foo.
Goal foo -> P.
intro f.
destruct f as [l] eqn:E.
induction l as [|hl tl].
Focus 2.
This gives:
1 subgoal
f : foo
hl : nat
tl : list nat
E : f = Foo (hl :: tl)
IHtl : f = Foo tl -> P
______________________________________(1/1)
P
Note that the IHtl induction hypothesis can't be used, as Foo(hl::tl) does not equal Foo tl.  Somehow, I need an equality relating f with Foo (hl::tl), but I don't want that equality to creep into the inductive hypothesis unless it stays the same.
Does anyone know a way around this?  I have tried various that end up with the same result.
-- Jonathan
