- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Induction with "eqn:" is broken?
- Date: Tue, 23 Sep 2014 21:12:17 -0400
On 09/23/2014 08:05 PM, Hugo Carvalho wrote:
My guess is that "generalize dependent f" between "destruct f as [l] eqn:E"
and "induction l as [|hl tl]" ought to do the trick.
The example, again:
Variable P : Prop.
Inductive foo : Type :=
| Foo (l : list nat) : foo.
Goal foo -> P.
intro f.
destruct f as [l] eqn:E.
generalize dependent f.
induction l as [|hl tl];intros.
Focus 2.
This gives:
1 subgoals
hl : nat
tl : list nat
IHtl : forall f : foo, f = Foo tl -> P
f : foo
E : f = Foo (hl :: tl)
______________________________________(1/1)
P
Thanks! In the case I'm interested in, having that particular inductive hypothesis works (I can construct the necessary "Foo tl", even though it isn't used). However, is it possible to keep the equality from the destruct, but not have it get incorporated into the inductive hypothesis at all? In other words, restrict the inductive hypotheses to what it would have been if there was no equation E at all (in this simplified case, just P alone)?
-- Jonathan
- [Coq-Club] Induction with "eqn:" is broken?, hugoccomp, 09/05/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Hugo Herbelin, 09/07/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/07/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/23/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Hugo Carvalho, 09/24/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/24/2014
