coq-club - Re: [Coq-Club] Induction with "eqn:" is broken?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Induction with "eqn:" is broken?
  • Date: Sun, 07 Sep 2014 11:33:08 -0400
On 09/07/2014 11:31 AM, Jonathan wrote:
What if induction eqn: did something instead like so:
Goal forall n, n+0=n.
intro n.
remember n as n0 eqn:E.
revert n n0 E.
induction n as [|n'].
-- Jonathan
Oh - I see that was suggested already - sorry.
On 09/07/2014 10:53 AM, Hugo Herbelin wrote:
Hi,
As it is implemented now, the "eqn:" modifier to induction is actually
pointless as it impacts the induction hypotheses in a way which makes
them useless. It is here by analogy with the "eqn:" for destruct, but
it is a posteriori an error to make it available for induction.
In any case, the primary use of the "eqn:" modifier was to remember
the value of the term destruct is applied on. If it also helps to
indicate which case of a case analysis proof is under consideration,
it is somehow incidental. Maybe one day will this information be made
available to the user without impacting the purely logical content of
the proof...
Hugo Herbelin
On Fri, Sep 05, 2014 at 02:50:13PM +0200,
hugoccomp AT gmail.com
wrote:
A friend of mine is working his way through Software Foundations and was using
its "Case" (and "SCase", etc) tactics to annotate the proof context.
Eventually the book introduced the "eqn:" extra option to the "destruct"
tactic, and it seemed like it was a a suitable replacement for that usage of
"Case" tatics, until he tried to use the same option with "induction".
induction n as [|n'] eqn:Heqn.
(*The first goal, 0+0=0, goes through normally...*)
reflexivity.
(*But here we are stuck - the equality generated by eqn: blocks usage of the
inductive hypothesis. *)
Is this behavior intended?
A similar "impossible" proof state is reached if,
instead of "induction n as [|n'] eqn:Heqn.", you start with "intro n;remember
n;induction n".
But if you're using "remember", you can "generalize dependent" the fresh term
before the induction
and then all goes through fine. I can't help but think that maybe "eqn:"
should be doing something similar behind the scenes.
Also i'm using Coq 8.4pl2 - if this is fixed on the later versions let me
know.
