- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Induction with "eqn:" is broken?
- Date: Tue, 23 Sep 2014 21:05:06 -0300
My guess is that "generalize dependent f" between "destruct f as [l] eqn:E" and "induction l as [|hl tl]" ought to do the trick.
The example, again:Variable P : Prop.
Inductive foo : Type :=
| Foo (l : list nat) : foo.
Goal foo -> P.
intro f.
destruct f as [l] eqn:E.
generalize dependent f.
induction l as [|hl tl];intros.
Focus 2.
This gives:
1 subgoals
hl : nat
tl : list nat
IHtl : forall f : foo, f = Foo tl -> P
f : foo
E : f = Foo (hl :: tl)
______________________________________(1/1)
P
2014-09-23 18:38 GMT-03:00 Jonathan <jonikelee AT gmail.com>:
On 09/07/2014 10:53 AM, Hugo Herbelin wrote:
Hi, As it is implemented now, the "eqn:" modifier to induction is actually pointless as it impacts the induction hypotheses in a way which makes them useless. It is here by analogy with the "eqn:" for destruct, but it is a posteriori an error to make it available for induction.
I think I have a case of this, but it is slightly different. The eqn: is modifying a destruct prior to the induction (case_eq ; intros works similarly), but the induction hypotheses are still messed up as a result. Here's a simplified example:
Variable P : Prop.This gives:
Goal foo -> P.
intro f.
induction l as [|hl tl].
Focus 2.
1 subgoal
f : foo
hl : nat
tl : list nat
IHtl : f = Foo tl -> P
P
Note that the IHtl induction hypothesis can't be used, as Foo(hl::tl) does not equal Foo tl. Somehow, I need an equality relating f with Foo (hl::tl), but I don't want that equality to creep into the inductive hypothesis unless it stays the same.
Does anyone know a way around this? I have tried various that end up with the same result.
-- Jonathan
- [Coq-Club] Induction with "eqn:" is broken?, hugoccomp, 09/05/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Hugo Herbelin, 09/07/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/07/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/23/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Hugo Carvalho, 09/24/2014
- Re: [Coq-Club] Induction with "eqn:" is broken?, Jonathan, 09/24/2014
