coq-club - Re: [Coq-Club] problem with tactic-generated terms
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] problem with tactic-generated terms
  • Date: Fri, 12 Sep 2014 10:55:40 -0400
On 09/12/2014 08:10 AM, Ömer Sinan Ağacan wrote:
Hi all,
I'm having trouble implementing even the simplest dependently typed
term using `Fixpoint`, `Definition` etc. I've been doing a lot of
proving using tactics lately and I'm very comfortable with tactics. So
I thought why not define everything using tactics? I came up with
this:
https://gist.github.com/osa1/47ed1dd4267fa379259d
Now before coming to the problem with this, here's a few things: (see
also generated OCaml link in the link above)
* The whole thing looks a bit complex but actually implementing it was
very, very easy. Definitely a lot easier than how it'd be if I wanted
to implement it without tactics.
Another benefit is how the interaction while developing the proof script helps one write programs.
* Even though generated Coq terms are huge, generated OCaml is
actually very good. It still has some problems though. `snoc` has a
redundant argument which could be eliminated by using OCaml lists for
vectors. First argument of `sum-pairs` is redundant because it's just
vector's length so we could use Vector.t's field instead. Similarly, I
think `pascal_aux`'s first argument may also be removed etc.
It is possible to remove such things as well. Some of this can be done using Coq's extraction options. But, for others, it takes a more comprehensive form of erasability than Coq currently has built in.
So I was actually happy with those definitions. But the problem is I
can't prove even the simplest fact about those definitions. I think
the reason is that `simpl.` no longer works.
First I tried some simple `Eval simpl in ...` commands but none of
them worked. I could compile OCaml files and run what I want just
fine, but in Coq it just doesn't work.
I tried `Eval compute in ...` but it just returned huge terms.
I think because of that I can't prove anything. See my lemma in the
link above. I should expect `simpl.` to make my goal `1 = 1`, but it
just doesn't work.
Yes - if you define a function using tactics like simple induction, you probably won't want to see into the function at all via unfold, simpl, etc. Such tactic-defined functions are often very large and unwieldy to work with, even if you could. This leads to a different style of proving, where one has to make sure that the type of a function encodes everything interesting about it - so that the function can remain opaque (you could just use Qed instead of Defined). This is not a style that everyone would appreciate, but it has other benefits. As long as one considers the extracted OCaml program to be what is being developed, and not the Coq "Gallina code" itself. It is also a more modular style of programming - because the only thing that depends on how a function is implemented is the function itself, not proofs about it (which depend only on the function's type).
The alternative is to learn about the "convoy pattern" that Adam Chlipala uses extensively in his CPDT book. However, when I was reading (a draft of) that CPDT book, it was precisely because of the convoy pattern and what weakness of Coq it covers up that I gave up Coq and learned Agda. I only came back to Coq when I realized I could use tactics to program effectively, use an added erasability feature to generate nice OCaml, and keep the types of functions sufficiently comprehensive that I never unfold/simpl/compute them within proofs.
By the way, inversion tactics use the convoy pattern themselves internally - they're just not very good about tailoring each usage of that pattern precisely to the specific need.
-- Jonathan
