- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] problem with tactic-generated terms
- Date: Fri, 12 Sep 2014 18:10:59 -0400
On 09/12/2014 06:04 PM, Jonathan wrote:
Inductive Erasable(A : Type) : Prop :=
erasable: A -> Erasable A.
Arguments erasable [A] _.
Axiom Erasable_inj : forall {A : Type}{a b : A}, erasable a=erasable
b -> a=b.
We did the same thing in Ynot, and I think this axiom turned out to be inconsistent, period. You don't need to assume any others to run into trouble. I don't remember the details of the proof, though.
- [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Greg Morrisett, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Matthieu Sozeau, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Robert Dockins, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/14/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/15/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/15/2014
