- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] problem with tactic-generated terms
- Date: Fri, 12 Sep 2014 18:04:30 -0400
On 09/12/2014 05:44 PM, Greg Morrisett wrote:
Uhm, I'm a little worried about this idea of selective proof
irrelevance and the interaction with an injectivity axiom
for some nat -> Prop constructor. This is exactly what we
wanted in Ynot, but I didn't see how to do it safely...
Can you say more Jonathan?
-Greg
Axiom proof_irrelevance : forall (P:Prop) (p1 p2:P), p1 = p2.
So, that certainly won't mix with:
Inductive Erasable(A : Type) : Prop :=
erasable: A -> Erasable A.
Arguments erasable [A] _.
Axiom Erasable_inj : forall {A : Type}{a b : A}, erasable a=erasable
b -> a=b.
A specific Prop P other than Erasable irrelevance:
Axiom P_irrelevance : forall (p1 p2:P), p1 = p2.
Maybe there is a problem here? I will try to create a contradiction in this case, using a Prop that is identical in structure to Erasable, but just not itself Erasable - that actually does look possible...
-- Jonathan
- [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Greg Morrisett, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Matthieu Sozeau, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Robert Dockins, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/14/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/15/2014
