- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] problem with tactic-generated terms
- Date: Fri, 12 Sep 2014 17:44:41 -0400
Uhm, I'm a little worried about this idea of selective proof
irrelevance and the interaction with an injectivity axiom
for some nat -> Prop constructor. This is exactly what we
wanted in Ynot, but I didn't see how to do it safely...
Can you say more Jonathan?
-Greg
On Sep 12, 2014, at 5:36 PM, Daniel Schepler
<dschepler AT gmail.com>
wrote:
> On Fri, Sep 12, 2014 at 1:52 PM, Jonathan
> <jonikelee AT gmail.com>
> wrote:
>> But, if one is willing, one can exploit the Prop universe to get such
>> things
>> erased. This can complicate things a bit - for example, you would need an
>> alternate definition of Vector - but that is fairly easy (if lengthy) to
>> achieve. To exploit the Prop universe this way requires adding an axiom -
>> with the usual consistency risks of doing so - but it is a very simple
>> axiom
>> that, as far as I know, is only incompatible with general proof-irrelevance
>> (among the typical other axioms that are frequently added to Coq), but not
>> with specific proof-irrelevance (defined separately for each Prop one
>> wishes
>> to be irrelevant, such as equality). The idea of this axiom is to make a
>> single Prop relevant by adding an injectivity axiom to its sole
>> constructor,
>> and to use "lifted" (into that single Prop) versions of types and values
>> you
>> want erased in those spots where you want them erased - and then allow
>> Coq's
>> normal Prop removal to do its thing. With careful handling, one can get
>> OCaml output from Coq with this addition that is quite clean.
> And here, all this time, I thought you were using something more like
> a singleton monad: passing an argument of type (nat -> Prop) in place
> of nat which is understood (or maybe even restricted) to be a
> singleton set. That should probably work along with proof
> irrelevance, maybe with an axiom like Extensionality_Ensembles but
> maybe even without it.
> Daniel Schepler
- [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Greg Morrisett, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Matthieu Sozeau, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Robert Dockins, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/14/2014
