- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Cc: "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>
- Subject: Re: [Coq-Club] forbid the use of an identifier?
- Date: Fri, 24 Oct 2014 14:26:21 +0200
I don't think there is. What sort of use-case do you have in mind?
On 24 October 2014 12:47, Vladimir Voevodsky <vladimir AT ias.edu> wrote:
Hello,
is there a way to make sure that a certain identifier can not be used? The closest that I know to it is to make an identifier opaque but
I would like to make sure that an identifier is not used at all, e.g., I would like to say
Hide identity_ind.
and then if a tactic wants to use it it will generate an error.
Vladimir.
- [Coq-Club] forbid the use of an identifier?, Vladimir Voevodsky, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Arnaud Spiwack, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Cedric Auger, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Robbert Krebbers, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Randy Pollack, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Carlos . SIMPSON, 10/24/2014
