- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Cc: "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>
- Subject: Re: [Coq-Club] forbid the use of an identifier?
- Date: Fri, 24 Oct 2014 09:07:19 -0400
Like others, I do not really see the point of such a feature. But maybe the following suffices for your particular example:
(* Disable generation of eliminators *)
Unset Elimination Schemes.
(* Redefine identity yourself. No eliminators will be generated *)
Inductive identity (A : Type) (a : A) : A -> Type :=
identity_refl : identity A a a.
If it is about "restricting" the use of an inductive type, you may want to look at Yves Bertot's private types.
On 10/24/2014 06:47 AM, Vladimir Voevodsky wrote:
Hello,
is there a way to make sure that a certain identifier can not be used? The
closest that I know to it is to make an identifier opaque but
I would like to make sure that an identifier is not used at all, e.g., I
would like to say
Hide identity_ind.
and then if a tactic wants to use it it will generate an error.
Vladimir.
- [Coq-Club] forbid the use of an identifier?, Vladimir Voevodsky, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Arnaud Spiwack, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Cedric Auger, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Robbert Krebbers, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Randy Pollack, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Carlos . SIMPSON, 10/24/2014
