- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] forbid the use of an identifier?
- Date: Fri, 24 Oct 2014 09:07:48 -0400
Vladimir,
If you want to prove some properties but not name the properties you
can use "Goal" instead of "Lemma".
Randy
On Fri, Oct 24, 2014 at 6:47 AM, Vladimir Voevodsky
<vladimir AT ias.edu>
wrote:
> Hello,
> is there a way to make sure that a certain identifier can not be used? The
> closest that I know to it is to make an identifier opaque but
> I would like to make sure that an identifier is not used at all, e.g., I
> would like to say
> Hide identity_ind.
> and then if a tactic wants to use it it will generate an error.
> Vladimir.
- [Coq-Club] forbid the use of an identifier?, Vladimir Voevodsky, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Arnaud Spiwack, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Cedric Auger, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Robbert Krebbers, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Randy Pollack, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Carlos . SIMPSON, 10/24/2014
