- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Cc: "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>
- Subject: Re: [Coq-Club] forbid the use of an identifier?
- Date: Fri, 24 Oct 2014 14:55:07 +0200
I guess it does not work, but you can still try to do something like: «Notation "'indentity_ind'" := (Coq.Init.True Coq.Init.False).» (or use Abbreviation).
The idea would be to create a notation to an ill-typed term.
As far as I can remember, Coq only checks that all terms inside of a notation are defined, but does not check types at Notation definition.
When 'identity_ind' would be used, it would trigger an error, as it is not well typed.
Note that this works only for terms defined AFTER the notation. And in case of "identity_rect", forbidding it this way would not forbid "identity_rec" which is defined from "identity_rect".
Like Arnaud, I do not really see the point of such a feature.
I guess it covers the case where you define at term with X_{rec,rect,ind} as identifier before defining an inductive called X.
In this case, it was either a bad idea to name it X_{rec,rect,ind} and this should be changed, or you want to replace the induction principle, in which case it is better to deactivate automatic generation of induction principle ("Unset Elimination Scheme." if I remember well) and then define your own.
2014-10-24 14:26 GMT+02:00 Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>:
I don't think there is. What sort of use-case do you have in mind?On 24 October 2014 12:47, Vladimir Voevodsky <vladimir AT ias.edu> wrote:Hello,
is there a way to make sure that a certain identifier can not be used? The closest that I know to it is to make an identifier opaque but
I would like to make sure that an identifier is not used at all, e.g., I would like to say
Hide identity_ind.
and then if a tactic wants to use it it will generate an error.
Vladimir.
.../Sedrikov\...
- [Coq-Club] forbid the use of an identifier?, Vladimir Voevodsky, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Arnaud Spiwack, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Cedric Auger, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Robbert Krebbers, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Randy Pollack, 10/24/2014
- Re: [Coq-Club] forbid the use of an identifier?, Carlos . SIMPSON, 10/24/2014
