coq-club - Re: [Coq-Club] forbid the use of an identifier?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] forbid the use of an identifier?
  • Date: Fri, 24 Oct 2014 16:33:15 +0200
Hi All,
This would seem like a good opportunity to plead, once again and for the n-th time, for a
working model of coq-in-coq that works within the system. One would wish to be able to reflect
out of it (with a function) and into it (with a tactic). That way, Vladimir could write a function which
verifies on the coq-in-coq expression that it doesn't use his identifier; and also check by
reflecting back out that his expression is the same as what he thought it was.
Best,
---Carlos
Le 24/10/2014 15:07, Randy Pollack a écrit :
Vladimir,
If you want to prove some properties but not name the properties you
can use "Goal" instead of "Lemma".
Randy
On Fri, Oct 24, 2014 at 6:47 AM, Vladimir Voevodsky
<vladimir AT ias.edu>
wrote:
Hello,
is there a way to make sure that a certain identifier can not be used? The
closest that I know to it is to make an identifier opaque but
I would like to make sure that an identifier is not used at all, e.g., I
would like to say
Hide identity_ind.
and then if a tactic wants to use it it will generate an error.
Vladimir.
