coq-club - Re: [Coq-Club] setoid rewriting -- naive questions
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] setoid rewriting -- naive questions
  • Date: Thu, 20 Nov 2014 19:58:08 -0800
On Nov 19, 2014, at 12:30 , Daniel Schepler <dschepler AT gmail.com> wrote:
I've replied privately to Vadim with my file, rewritten to use standard library Vector.t.  f_equiv works beautifully after changing Vector.cons to vcons_reord, though the rewrite still isn't working.
While I am still studying Daniel’s solution which is quite involved I could not help thinking that should be an easier way to do this.
I want to use simple setoid rewriting here. For example, why it does not work here:
Proof state:
1 subgoals, subgoal 1 (ID 1804)
  B : Type
  H : Equiv B
  A : Type
  f : A → A → B
  CO : ∀ x y : A, f x y = f y x
  SB : Setoid B
  n : nat
  a : vector A (S n)
  b : vector A (S n)
  IHn : ∀ a0 b0 : vector A n, map2 f a0 b0 = map2 f b0 a0
   VConsR (map2 f (Vtail a) (Vtail b)) (f (Vhead a) (Vhead b)) = map2 f b a
I want to swap arguments of ‘f'. Using standard ‘eq’ I could easily do that by:
setoid_replace  (f (Vhead a) (Vhead b)) with (f (Vhead b) (Vhead a)) using relation (@eq B).
and I will get
(… same context as above ...)
   VConsR (map2 f (Vtail a) (Vtail b)) (f (Vhead b) (Vhead a)) = map2 f b a
subgoal 2 (ID 1821) is:
 f (Vhead a) (Vhead b) ≡ f (Vhead b) (Vhead a)
Which is what I expect. However if I try to do the same trick using ‘equiv’:
  setoid_replace  (f (Vhead a) (Vhead b)) with (f (Vhead b) (Vhead a)) using relation (@equiv B).
I get the following error:
Toplevel input, characters 0-94:
In nested Ltac calls to "setoid_replace" and "(rel x y)" (with rel:=equiv,
y:=f (Vhead b) (Vhead a), x:=f (Vhead a) (Vhead b)), last term evaluation
failed.
Error:
In environment
B : Type
H : Equiv B
A : Type
f : A → A → B
SB : Setoid B
n : nat
a : vector A (S n)
b : vector A (S n)
The term "f (Vhead a) (Vhead b)" has type "B"
 while it is expected to have type "Equiv B".
Am I using wrong syntax here or the problem's elsewhere?
Thanks!
Sincerely,
Vadim
