coq-club - Re: [Coq-Club] setoid rewriting -- naive questions
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] setoid rewriting -- naive questions
  • Date: Thu, 20 Nov 2014 22:15:45 -0800
On Thu, Nov 20, 2014 at 7:58 PM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
While I am still studying Daniel’s solution which is quite involved I could not help thinking that should be an easier way to do this.
I want to use simple setoid rewriting here. For example, why it does not work here:
Proof state:
1 subgoals, subgoal 1 (ID 1804)
  B : Type
  H : Equiv B
  A : Type
  f : A → A → B
  CO : ∀ x y : A, f x y = f y x
  SB : Setoid B
  n : nat
  a : vector A (S n)
  b : vector A (S n)
  IHn : ∀ a0 b0 : vector A n, map2 f a0 b0 = map2 f b0 a0
   VConsR (map2 f (Vtail a) (Vtail b)) (f (Vhead a) (Vhead b)) = map2 f b a
I want to swap arguments of ‘f'. Using standard ‘eq’ I could easily do that by:
setoid_replace  (f (Vhead a) (Vhead b)) with (f (Vhead b) (Vhead a)) using relation (@eq B).
and I will get
(… same context as above ...)
   VConsR (map2 f (Vtail a) (Vtail b)) (f (Vhead b) (Vhead a)) = map2 f b a
subgoal 2 (ID 1821) is:
 f (Vhead a) (Vhead b) ≡ f (Vhead b) (Vhead a)
Which is what I expect. However if I try to do the same trick using ‘equiv’:
  setoid_replace  (f (Vhead a) (Vhead b)) with (f (Vhead b) (Vhead a)) using relation (@equiv B).
@equiv is of type (forall (A:Type), Equiv A -> (A -> A -> Prop)).  You probably want (@equiv B _) to let it autoresolve the instance of Equiv B to fill in for the second argument.
By the way, we finally figured out how to get rewriting to work as expected: it turned out to be a case where putting in a copy of the original Proper instance, but with slightly relabeled type, allowed the system to resolve the properness.  i.e. the original was Proper ((=) ==> vector_equiv ==> vector_equiv), the copy was Proper ((=) ==> (=) ==> (=)).
Daniel Schepler
