coq-club - Re: [Coq-Club] setoid rewriting -- naive questions
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] setoid rewriting -- naive questions
  • Date: Fri, 21 Nov 2014 01:13:40 -0800
With huge help from Daniel we have been able to work out a solution.
I will summarize my findings in case somebody interested. The main missing
part
was proving Proper for Vcons. It requires two things:
1. Reordering Vcons arguments. I did this like this:
Definition VConsR {A} {n} (t: vector A n) (h:A): vector A (S n) := Vcons h t.
Lemma ConsR_VConsR: forall A n (t: t A n) (h:A), Vcons h t ≡ VConsR t h.
Proof.
intros. reflexivity.
Qed.
2. Proving 'Proper' instance:
Global Instance vconsR_proper `{Equiv A} n:
Proper (@vec_equiv A _ n ==> (=) ==> @vec_equiv A _ (S n))
(@VConsR A n).
Proof.
split.
assumption.
unfold vec_equiv, Vforall2 in H0. assumption.
Qed.
Now to use commutativity in the original proof we can just do:
rewrite ConsR_VConsR.
rewrite commutativity.
My only remaining regret is that I have two to 2 steps to apply commutativity
to Vcons.
I guess this could be automated via custom tactics, but I have not even
started learning LTAC :)
Vadim
> On Nov 18, 2014, at 11:25 , Vadim Zaliva
> <vzaliva AT cmu.edu>
> wrote:
> I am trying to prove following lemma:
> Lemma map2_setoid_comm `{Equiv B} `{Commutative B A}:
> forall n (a b: vector A n),
> (map2 f a b) = (map2 f b a).
> I am using Equiv and Commutative type classes from CoRN. For convenience I
> am also using VecUtil from CoLoR which provide several handy definitions
> for fixed-size vectors.
> Require Import abstract_algebra orders.minmax interfaces.orders.
> Require Import MathClasses.theory.rings.
> Require Import CoLoR.Util.Vector.VecUtil.
> Import VectorNotations.
> The equivalence used here (=) is 'equiv'. I was able to instantiate:
> Definition vec_equiv `{Equiv A} {n}: relation (vector A n) := Vforall2
> (n:=n) equiv.
> Instance vec_Equiv `{Equiv A} {n}: Equiv (vector A n) := vec_equiv.
> which permitted me to use reflexivity tactics to prove IH. Now I am trying
> to use 'commutativity' but no luck so far:
> 1 subgoals, subgoal 1 (ID 1405)
> B : Type
> H : Equiv B
> H0 : Equiv B
> A : Type
> f : A → A → B
> H1 : Commutative f
> n : nat
> a : vector A (S n)
> b : vector A (S n)
> IHn : ∀ a0 b0 : vector A n, map2 f a0 b0 = map2 f b0 a0
> Vcons (f (Vhead a) (Vhead b)) (map2 f (Vtail a) (Vtail b)) = map2 f b a
> As the next step I want rewrite LHS cons head by replacing (f (Vhead a)
> (Vhead b)) with (f (Vhead b) (Vhead a)) by commutativity. I could not make
> it work with any of rewrite tactics.
> I will appreciate if somebody would point me in the right direction. Thanks!
> Sincerely,
> Vadim
Sincerely,
Vadim Zaliva
CMU ECE PhD student
Mobile: +1(510)220-1060
Skype: vzaliva
