coq-club - Re: [Coq-Club] gprogress tactical?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] gprogress tactical?
  • Date: Sat, 24 Jan 2015 19:39:50 -0500
On 01/24/2015 06:53 PM, Pierre-Marie Pédrot wrote:
On 24/01/2015 22:38, Jonathan Leivent wrote:
[Requesting a fix to this will result in some Coq developer informing
you that Tactic Notation is an abomination.]
Me, most probably. And indeed, this is an abomination. It does not hurt
to remind it to the face of the earth.
That said though, I do have future plans to try to fix the tactic
notation mechanism, making it true notations (and thus breaking all
hackish code relying on it, you've been warned). But that's a long-term
task...
Anyway, I recommend the use of ML-level tactics in this case instead of
ugly hacks, now that in 8.5 the former were tweaked to respect the
module scoping system.
PMP
Will there be documentation on ML-level tactics, instead of merely pointing out some github project that is several years out of date, and lacking in sufficient detail regardless? That is all I received the last time I asked.
As for those hacks - I was hoping that their ugliness - which is required to accomplish such tasks entirely in Ltac as it stands - would perhaps help instigate better Ltac constructs and design. After all, it is one thing to say "it would be nice if", but perhaps more encouraging of change to say "look how useful this is, though it is painful to look at, and probably unmaintainable". The second also allows progress while waiting for change.
But, I will do both. The first did succeed in getting "multimatch" - although perhaps because that was easy due to how match already was implemented. I'll even learn how to write ML-level tactics, once the proper doc is made available.
-- Jonathan
