Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
- Date: Thu, 9 Apr 2015 15:21:28 +0200
2015-04-09 14:32 GMT+02:00 nicolas tabareau <nicolas.tabareau AT inria.fr>:
Hi,I have difficulty in proving equality on terms of adependent type that uses pattern matching.Here is a simplified example (that works withthe code given at the end of the mail).I start by defining a type depending on two naturals,which is True when they are equal and false otherwise.Definition GS1 := fun n m => match decpaths_nat n m withinl _ => True| inr _ => False end.I can defined a kind of composition and identity.Definition Compo {x y z} : GS1 x y -> GS1 y z -> GS1 x z.intros e e'. unfold GS1 in *.destruct (decpaths_nat x y). destruct (decpaths_nat y z).- rewrite (decpaths_nat_eq (e0 @ e1)).2. exact I.- destruct e'.- destruct e.Defined.Definition Id x : GS1 x x.red. rewrite (decpaths_nat_eq eq_refl).2. exact I.Defined.But then, I am not able to prove a simple identity law(at least by trying to use the pattern matching directly)Definition Id_R x y : forall (e:GS1 x y), Compo e (Id y) = e.(* does not work *)unfold GS1, Compo. simpl.destruct (decpaths_nat y y).Can anyone help me ?Thanks,-- Nicolas
I would start by proving the following:
"forall x y (g h : GS1 x y), g = h"
As we know, "GS1 x y" either reduces to "True" or to "False", thus this equality should be provable.
Once you have it, "Compo e (Id y)" and "e" are both of type "GS1 x y", and thus are equal.
So the question is how to prove the first lemma.
First introduce x and y, then unfold GS1. You should have:
"forall (g h : match decpaths_nat x y with … end), g = h."
From here, simply "case/destruct/whatever_elimination_principle (decpaths_nat x y)", and you end up with the following two subgoals to prove:
"forall (g h : True), g = h"
"forall (g h : False), g = h"
both of them are solvable with "intros [] []; split." (in fact, "intros []." is enough for the second goal).
- [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Cedric Auger, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Adam Chlipala, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Assia Mahboubi, 04/11/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/22/2015
