Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
- Date: Sat, 11 Apr 2015 00:32:47 +0200
Hi Nicolas,
with an isomorphic version of type GS1, things seem much easier (see the
attachment).
I guess I would need more context to know if this remark is of any help beyond
the toy example.
Best,
assia
Le 09/04/2015 17:22, nicolas tabareau a écrit :
> order and (L) are ok.
> Definition order: forall {x y}, GS1 x y -> nat :=
> fun x y =>
> match decpaths_nat x y as z return
> match z with inl _ => nat | inr _ => False end -> nat with
> | inl _ => fun (n:nat) => n
> | inr _ => fun (abs:False) => match abs return nat with end
> end.
> Definition L x y : forall (g h : GS1 x y), order g = order h -> g = h.
> unfold GS1, order.
> destruct (decpaths_nat x y); intros.
> - exact H.
> - destruct g.
> Defined.
> The proof of "order (Compo a b) = order b + order a" might be a little
> tricky, I did not tried it.
> This seems just to have change the dependent issue to this new lemma
> which I don't know how to prove ...
> Also, I would add, that I am not very found of the use of terms defined
> with
> tactics, when the definition is relevant.
> Such terms tend to be quite big, and totally unreadable. Having a "nice"
> definition of Compo could also help you in your proofs.
> Agreed, I usually avoid it too. But here I think the definition will look
> the same,
> except maybe for the rewrite if I use a transport.
nicolas.v
Description: application/save-to-disk
- [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Cedric Auger, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Adam Chlipala, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Assia Mahboubi, 04/11/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/22/2015
