Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
- From: nicolas tabareau <nicolas.tabareau AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
- Date: Thu, 9 Apr 2015 16:13:03 +0200
Thanks Cédric and Adam for your help.
I realise that my example was too simplified
so it could be solved without facing the issue
I have.
Consider this one, where nat is used instead of True.
I still don't know how to prove the id_R law, even
with Adam insight.
Definition GS1 := fun n m => match decpaths_nat n m with
inl _ => nat
| inr _ => False end.
Definition Compo {x y z} : GS1 x y -> GS1 y z -> GS1 x z.
intros e e'. unfold GS1 in *.
destruct (decpaths_nat x y). destruct (decpaths_nat y z).
- rewrite (decpaths_nat_eq (e0 @ e1)).2. exact (e+e').
- destruct e'.
- destruct e.
Defined.
Definition Id x : GS1 x x.
red. rewrite (decpaths_nat_eq eq_refl).2. exact 0.
Defined.
On Thu, Apr 9, 2015 at 2:32 PM, nicolas tabareau <nicolas.tabareau AT inria.fr> wrote:
Hi,I have difficulty in proving equality on terms of adependent type that uses pattern matching.Here is a simplified example (that works withthe code given at the end of the mail).I start by defining a type depending on two naturals,which is True when they are equal and false otherwise.Definition GS1 := fun n m => match decpaths_nat n m withinl _ => True| inr _ => False end.I can defined a kind of composition and identity.Definition Compo {x y z} : GS1 x y -> GS1 y z -> GS1 x z.intros e e'. unfold GS1 in *.destruct (decpaths_nat x y). destruct (decpaths_nat y z).- rewrite (decpaths_nat_eq (e0 @ e1)).2. exact I.- destruct e'.- destruct e.Defined.Definition Id x : GS1 x x.red. rewrite (decpaths_nat_eq eq_refl).2. exact I.Defined.But then, I am not able to prove a simple identity law(at least by trying to use the pattern matching directly)Definition Id_R x y : forall (e:GS1 x y), Compo e (Id y) = e.(* does not work *)unfold GS1, Compo. simpl.destruct (decpaths_nat y y).Can anyone help me ?Thanks,-- Nicolas(* some code to be used with the example above *)Notation "x .1" := (projT1 x) (at level 3).Notation "x .2" := (projT2 x) (at level 3).Inductive Empty : Type.Definition not (T : Type) := T -> Empty.Notation "~~ A" := (not A) (at level 75).Definition concat {A : Type} {x y z : A} (p : x = y) (q : y = z) : x = z.destruct p; exact q.Defined.Notation "p @ q" := (concat p q) (at level 20) : type_scope.Parameter decpaths_nat : forall (x y : nat), (x = y) + ~~ (x = y).Parameter decpaths_nat_eq : forall {g g'} (e: g = g'),{e' : g = g' & decpaths_nat g g' = inl e'}.Parameter decpaths_nat_neq : forall {g g'} ( e : ~~ g = g'),{e' : ~~ g = g' & decpaths_nat g g' = inr e'}.
Nicolas Tabareau
Researcher at Inria
Ascola Group, Nantes
Researcher at Inria
- [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Cedric Auger, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Adam Chlipala, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Assia Mahboubi, 04/11/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/22/2015
