Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
- Date: Thu, 9 Apr 2015 16:40:07 +0200
In this case, you should be able to define a function "order" of type:
"forall x y, GS1 x y -> nat"
which satisfies (L):
"forall x y (g h : GS1 x y), order g = order h -> g = h".
The order function can be defined as:
"fun x y =>
match decpaths_nat x y as z in match z with inl _ => nat | _ => False end -> nat end with
| inl _ => fun (n:nat) => n
| inr _ => fun (abs:False) => match abs return nat with end
end"
(L) can now be proved simply with something like:
"intros x y; unfold order; unfold GS1; destruct (decpaths_nat x y); simpl; auto; intros []."
I did not try it, so it may not work as easily, but I am pretty confident it should not be much harder.
Now, you have to prove that "order (Compo a b) = order b + order a" and that "order (Id x) = 0".
With that you can conclude that "order (Compo g (Id y)) = 0+order g = order g", and thus "Compo g (Id y) = g".
The proof of "order (Compo a b) = order b + order a" might be a little tricky, I did not tried it.
Also, I would add, that I am not very found of the use of terms defined with tactics, when the definition is relevant.
Such terms tend to be quite big, and totally unreadable. Having a "nice" definition of Compo could also help you in your proofs.
2015-04-09 16:13 GMT+02:00 nicolas tabareau <nicolas.tabareau AT inria.fr>:
Thanks Cédric and Adam for your help.I realise that my example was too simplifiedso it could be solved without facing the issueI have.Consider this one, where nat is used instead of True.I still don't know how to prove the id_R law, evenwith Adam insight.Definition GS1 := fun n m => match decpaths_nat n m withinl _ => nat| inr _ => False end.Definition Compo {x y z} : GS1 x y -> GS1 y z -> GS1 x z.intros e e'. unfold GS1 in *.destruct (decpaths_nat x y). destruct (decpaths_nat y z).- rewrite (decpaths_nat_eq (e0 @ e1)).2. exact (e+e').- destruct e'.- destruct e.Defined.Definition Id x : GS1 x x.red. rewrite (decpaths_nat_eq eq_refl).2. exact 0.Defined.On Thu, Apr 9, 2015 at 2:32 PM, nicolas tabareau <nicolas.tabareau AT inria.fr> wrote:Hi,I have difficulty in proving equality on terms of adependent type that uses pattern matching.Here is a simplified example (that works withthe code given at the end of the mail).I start by defining a type depending on two naturals,which is True when they are equal and false otherwise.Definition GS1 := fun n m => match decpaths_nat n m withinl _ => True| inr _ => False end.I can defined a kind of composition and identity.Definition Compo {x y z} : GS1 x y -> GS1 y z -> GS1 x z.intros e e'. unfold GS1 in *.destruct (decpaths_nat x y). destruct (decpaths_nat y z).- rewrite (decpaths_nat_eq (e0 @ e1)).2. exact I.- destruct e'.- destruct e.Defined.Definition Id x : GS1 x x.red. rewrite (decpaths_nat_eq eq_refl).2. exact I.Defined.But then, I am not able to prove a simple identity law(at least by trying to use the pattern matching directly)Definition Id_R x y : forall (e:GS1 x y), Compo e (Id y) = e.(* does not work *)unfold GS1, Compo. simpl.destruct (decpaths_nat y y).Can anyone help me ?Thanks,-- Nicolas(* some code to be used with the example above *)Notation "x .1" := (projT1 x) (at level 3).Notation "x .2" := (projT2 x) (at level 3).Inductive Empty : Type.Definition not (T : Type) := T -> Empty.Notation "~~ A" := (not A) (at level 75).Definition concat {A : Type} {x y z : A} (p : x = y) (q : y = z) : x = z.destruct p; exact q.Defined.Notation "p @ q" := (concat p q) (at level 20) : type_scope.Parameter decpaths_nat : forall (x y : nat), (x = y) + ~~ (x = y).Parameter decpaths_nat_eq : forall {g g'} (e: g = g'),{e' : g = g' & decpaths_nat g g' = inl e'}.Parameter decpaths_nat_neq : forall {g g'} ( e : ~~ g = g'),{e' : ~~ g = g' & decpaths_nat g g' = inr e'}.--Nicolas Tabareau
Researcher at Inria
Ascola Group, Nantes
- [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Cedric Auger, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Adam Chlipala, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/09/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, Assia Mahboubi, 04/11/2015
- Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching, nicolas tabareau, 04/22/2015
