coq-club - Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] equality on terms of a dependent type that uses pattern matching
  • Date: Thu, 09 Apr 2015 09:40:37 -0400
Here's another solution. It applies the general idea of generalizing over proof terms from the goal, when the types of those proof terms mention the term you want to [destruct].
Ltac contra :=
match goal with
| [ H : _ |- _ ] => destruct H; solve [ auto ]
end.
Lemma True_irrel : forall pf1 pf2 : True, pf1 = pf2.
Proof.
destruct pf1, pf2; auto.
Qed.
Definition Id_R x y : forall (e:GS1 x y), Compo e (Id y) = e.
unfold GS1, Compo. simpl.
generalize (@decpaths_nat_eq x y).
destruct (decpaths_nat x y); intros; try contra.
apply True_irrel.
Qed.
On 04/09/2015 08:32 AM, nicolas tabareau wrote:
Hi,
I have difficulty in proving equality on terms of a
dependent type that uses pattern matching.
Here is a simplified example (that works with
the code given at the end of the mail).
I start by defining a type depending on two naturals,
which is True when they are equal and false otherwise.
Definition GS1 := fun n m => match decpaths_nat n m with
inl _ => True
| inr _ => False end.
I can defined a kind of composition and identity.
Definition Compo {x y z} : GS1 x y -> GS1 y z -> GS1 x z.
intros e e'. unfold GS1 in *.
destruct (decpaths_nat x y). destruct (decpaths_nat y z).
- rewrite (decpaths_nat_eq (e0 @ e1)).2. exact I.
- destruct e'.
- destruct e.
Defined.
Definition Id x : GS1 x x.
red. rewrite (decpaths_nat_eq eq_refl).2. exact I.
Defined.
But then, I am not able to prove a simple identity law
(at least by trying to use the pattern matching directly)
(* does not work *)
destruct (decpaths_nat y y).
Can anyone help me ?
Thanks,
-- Nicolas
(* some code to be used with the example above *)
Notation "x .1" := (projT1 x) (at level 3).
Notation "x .2" := (projT2 x) (at level 3).
Inductive Empty : Type.
Definition not (T : Type) := T -> Empty.
Notation "~~ A" := (not A) (at level 75).
Definition concat {A : Type} {x y z : A} (p : x = y) (q : y = z) : x = z.
destruct p; exact q.
Defined.
Notation "p @ q" := (concat p q) (at level 20) : type_scope.
Parameter decpaths_nat : forall (x y : nat), (x = y) + ~~ (x = y).
Parameter decpaths_nat_eq : forall {g g'} (e: g = g'),
{e' : g = g' & decpaths_nat g g' = inl e'}.
Parameter decpaths_nat_neq : forall {g g'} ( e : ~~ g = g'),
{e' : ~~ g = g' & decpaths_nat g g' = inr e'}.
