- From: FOURNIER Laurent <laurent.fournier AT irt-saintexupery.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Newbies Question
- Date: Thu, 21 May 2015 09:26:06 +0000
- Accept-language: fr-FR, en-US
Hello everyone, I’m new on this mailing list…I do not know if posts can be in French or should be in English !
My concern is about the following Python code (can be translated in any language !) ________________________________________________ def value(d, f, i, p, k, x): assert d>0 and f>=d and x>=0 and x<=100 and i>0 and p>=0 and k>=0 #PRECOND if i == 1: return d, 1 r, s = p if k==i-1 else p-1, 1 if p==1 else 0 u, v = (i-1)*(p-1)+k+s, (i-1)*(p-1)+k+r if v > f: v = f t = ((100-x)*u+x*v)//100 q = (t-1)//i return 1+q, t-i*q
def simu(d, f, x): print ('init:%d final:%d speed:%d' % (d, f, x)) po, ko, to = d, 0, 0 for i in range(1, f+10): p, k = value(d, f, i, po, ko, x) t, po, ko = k*p +(i-k)*(p-1), p, k assert p>0 and k>0 #POST0 if p == po: assert k<=ko #POST1 else: assert p<po and t>=to #POST2 to = t print ('%d: %d*%d+%d*%d=%d' % (i, k, p, i-k, p-1, t))
if __name__ == '__main__': for j in range (1, 200): # for instance ! for s in range(101): simu(d=j, f=679, x=s)
A simple simulation shows that the assertions in POST0,1,2 never raise, but I need a FORMAL PROOF that I can remove those 3 lines and be sure that the post-conditions will always be verified. (All parameters are integers and // means “integer division”)
I also need to put the proof in a LaTeX formatted paper if not too long.
Question: Is COQ the right tool to get this proof ? (consider I do not know COQ and do not expect to spend 2 years in training for that) If the answer is YES, which lab could be able to do the job (get the proof) ?
Merci d’avance pour votre aide,
Laurent Fournier, PhD.
- [Coq-Club] Newbies Question, FOURNIER Laurent, 05/21/2015
- Re: [Coq-Club] Newbies Question, Nuno Gaspar, 05/21/2015
- RE: [Coq-Club] Newbies Question, Soegtrop, Michael, 05/21/2015
- Re: [Coq-Club] Newbies Question, Cedric Auger, 05/21/2015
- Re: [Coq-Club] Newbies Question, Christophe Bal, 05/21/2015
- Re: [Coq-Club] Newbies Question, Gabriel Scherer, 05/21/2015
