coq-club - RE: [Coq-Club] Newbies Question
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Newbies Question
  • Date: Thu, 21 May 2015 15:51:28 +0000
  • Accept-language: de-DE, en-US
Dear Laurent,
I gave it a quick try in Coq as an exercise. I transcribed your python to Coq Gallina and tried to prove:
Theorem simuok: forall d f x : nat, simu d f x = true.
Here simu returns the and of all asserts over all loop iterations. It shows quickly that this fails for d=f=x=0 (your python code agrees on this). So for what ranges should it hold? Or should it just hold for all d and x with f=679?
Best regards,
Michael
From: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr] On Behalf Of FOURNIER Laurent
Sent: Thursday, May 21, 2015 11:26 AM
To: coq-club AT inria.fr
Subject: [Coq-Club] Newbies Question
Hello everyone,
I’m new on this mailing list…I do not know if posts can be in French or should be in English !
My concern is about the following Python code (can be translated in any language !)
________________________________________________
def value(d, f, i, p, k, x):
    assert d>0 and f>=d and x>=0 and x<=100 and i>0 and p>=0 and k>=0 #PRECOND
    if i == 1: return d, 1
    r, s = p if k==i-1 else p-1, 1 if p==1 else 0
    u, v = (i-1)*(p-1)+k+s, (i-1)*(p-1)+k+r
    if v > f: v = f
    t = ((100-x)*u+x*v)//100
    q = (t-1)//i
    return 1+q, t-i*q
def simu(d, f, x):
    print ('init:%d final:%d speed:%d' % (d, f, x))
    po, ko, to = d, 0, 0
    for i in range(1, f+10):
        p, k = value(d, f, i, po, ko, x)
        t, po, ko = k*p +(i-k)*(p-1), p, k
        assert p>0 and k>0                  #POST0
        if p == po: assert k<=ko         #POST1
        else: assert p<po and t>=to #POST2
        to = t
        print ('%d: %d*%d+%d*%d=%d' % (i, k, p, i-k, p-1, t))
if __name__ == '__main__':
    for j in range (1, 200): # for instance !
        for s in range(101):
            simu(d=j, f=679, x=s)
A simple simulation shows that the assertions in POST0,1,2 never raise, but I need a FORMAL PROOF that I can remove those 3 lines and be sure that the post-conditions will always be verified. (All parameters are integers and // means “integer division”)
I also need to put the proof in a LaTeX formatted paper if not too long.
Question: Is COQ the right tool to get this proof ?
(consider I do not know COQ and do not expect to spend 2 years in training for that)
If the answer is YES, which lab could be able to do the job (get the proof) ?
Merci d’avance pour votre aide,
Laurent Fournier, PhD.
