- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Newbies Question
- Date: Thu, 21 May 2015 20:47:49 +0200
Dear Christophe,
If your question is about the transcript from python to Coq, rather than the proof, please find it below. I did it quite quickly, so quite possible that I made a flaw. Maybe Laurent can comment on this. The main difference is that I used nat instead of Z. I did it like this because my automation system cannot handle Z well as yet, and I just wanted to give it a quick try out of curiosity. It is difficult to compare results with the python code, because simu doesn’t really compute a value one could compare for a few sample values besides the assert results. The basic structure of the code should be ok, though. The transcript is done pretty much 1:1 without some simplifications one could do.
Best regards,
Michael
Require Import Nat.
Definition value (d f i p k x : nat) : nat * nat :=
match i with
| 1 => (d,1)
| _ =>
let r := if k =? (i-1) then p else p-1 in
let s := if p =? 1 then 1 else 0 in
let u := (i-1)*(p-1)+k+s in
let v := (i-1)*(p-1)+k+r in
let v' := if f <? v then f else v in
let t := ((100-x)*u+x*v')/100 in
let q := (t-1)/i in
(1+q, t-i*q)
end.
Fixpoint simuloop (n i d f x po ko to: nat) : bool :=
match n with
| 0 => true
| S n' =>
let (p,k) := value d f i po ko x in
let t := k*p +(i-k)*(p-1) in
let po' := p in
let ko' := k in
let check :=
andb (andb (0<?p) (0<?k))
(if p =? po' then k<=?ko'
else andb (p <? po') (to<=?t)) in
let to' := t in
andb check (simuloop n' (i+1) d f x po' ko' to')
end.
Definition simu (d f x : nat) : bool :=
simuloop (f+10-1) 1 d f x d 0 0.
- [Coq-Club] Newbies Question, FOURNIER Laurent, 05/21/2015
- Re: [Coq-Club] Newbies Question, Nuno Gaspar, 05/21/2015
- RE: [Coq-Club] Newbies Question, Soegtrop, Michael, 05/21/2015
- Re: [Coq-Club] Newbies Question, Cedric Auger, 05/21/2015
- Re: [Coq-Club] Newbies Question, Christophe Bal, 05/21/2015
- Re: [Coq-Club] Newbies Question, Gabriel Scherer, 05/21/2015
- Re: [Coq-Club] Newbies Question, Pierre Courtieu, 05/22/2015
- RE: [Coq-Club] Newbies Question, FOURNIER Laurent, 05/26/2015
