coq-club - RE: [Coq-Club] Newbies Question
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Newbies Question
  • Date: Thu, 21 May 2015 18:01:32 +0000
  • Accept-language: de-DE, en-US
Dear Christophe,
If your question is about the transcript from python to Coq, rather than the proof, please find it below. I did it quite quickly, so quite possible that I made a flaw. Maybe Laurent can comment on this. The main difference is that I used nat instead of Z. I did it like this because my automation system cannot handle Z well as yet, and I just wanted to give it a quick try out of curiosity. It is difficult to compare results with the python code, because simu doesn’t really compute a value one could compare for a few sample values besides the assert results. The basic structure of the code should be ok, though. The transcript is done pretty much 1:1 without some simplifications one could do.
Best regards,
Michael
Require Import Nat.
Definition value (d f i p k x : nat) : nat * nat :=
  match i with
  | 1 => (d,1)
  | _ =>
    let r := if k =? (i-1) then p else p-1 in
    let s := if p =? 1 then 1 else 0 in
    let u := (i-1)*(p-1)+k+s in
    let v := (i-1)*(p-1)+k+r in
    let v' := if f <? v then f else v in
    let t := ((100-x)*u+x*v')/100 in
    let q := (t-1)/i in
    (1+q, t-i*q)
  end.
Fixpoint simuloop (n i d f x po ko to: nat) : bool :=
  match n with
  | 0 => true
  | S n' =>
    let (p,k) := value d f i po ko x in
    let t := k*p +(i-k)*(p-1) in
    let po' := p in
    let ko' := k in
    let check :=
      andb (andb (0<?p) (0<?k))
      (if p =? po' then k<=?ko'
       else andb (p <? po') (to<=?t)) in
    let to' := t in
      andb check (simuloop n' (i+1) d f x po' ko' to')
  end.
Definition simu (d f x : nat) : bool :=
  simuloop (f+10-1) 1 d f x d 0 0.
