- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Newbies Question
- Date: Thu, 21 May 2015 18:19:16 +0200
I gave it a quick try in Coq as an exercise. I transcribed your python to Coq Gallina and tried to prove:
Theorem simuok: forall d f x : nat, simu d f x = true.
Here simu returns the and of all asserts over all loop iterations. It shows quickly that this fails for d=f=x=0 (your python code agrees on this). So for what ranges should it hold? Or should it just hold for all d and x with f=679?
Best regards,
Michael
From: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr] On Behalf Of FOURNIER Laurent
Sent: Thursday, May 21, 2015 11:26 AM
To: coq-club AT inria.fr
Subject: [Coq-Club] Newbies Question
Hello everyone,
I’m new on this mailing list…I do not know if posts can be in French or should be in English !
My concern is about the following Python code (can be translated in any language !)
________________________________________________
def value(d, f, i, p, k, x):
assert d>0 and f>=d and x>=0 and x<=100 and i>0 and p>=0 and k>=0 #PRECOND
if i == 1: return d, 1
r, s = p if k==i-1 else p-1, 1 if p==1 else 0
u, v = (i-1)*(p-1)+k+s, (i-1)*(p-1)+k+r
if v > f: v = f
t = ((100-x)*u+x*v)//100
q = (t-1)//i
return 1+q, t-i*q
def simu(d, f, x):
print ('init:%d final:%d speed:%d' % (d, f, x))
po, ko, to = d, 0, 0
for i in range(1, f+10):
p, k = value(d, f, i, po, ko, x)
t, po, ko = k*p +(i-k)*(p-1), p, k
assert p>0 and k>0 #POST0
if p == po: assert k<=ko #POST1
else: assert p<po and t>=to #POST2
to = t
print ('%d: %d*%d+%d*%d=%d' % (i, k, p, i-k, p-1, t))
if __name__ == '__main__':
for j in range (1, 200): # for instance !
for s in range(101):
simu(d=j, f=679, x=s)
A simple simulation shows that the assertions in POST0,1,2 never raise, but I need a FORMAL PROOF that I can remove those 3 lines and be sure that the post-conditions will always be verified. (All parameters are integers and // means “integer division”)
I also need to put the proof in a LaTeX formatted paper if not too long.
Question: Is COQ the right tool to get this proof ?
(consider I do not know COQ and do not expect to spend 2 years in training for that)
If the answer is YES, which lab could be able to do the job (get the proof) ?
Merci d’avance pour votre aide,
Laurent Fournier, PhD.
- [Coq-Club] Newbies Question, FOURNIER Laurent, 05/21/2015
- Re: [Coq-Club] Newbies Question, Nuno Gaspar, 05/21/2015
- RE: [Coq-Club] Newbies Question, Soegtrop, Michael, 05/21/2015
- Re: [Coq-Club] Newbies Question, Cedric Auger, 05/21/2015
- Re: [Coq-Club] Newbies Question, Christophe Bal, 05/21/2015
- Re: [Coq-Club] Newbies Question, Gabriel Scherer, 05/21/2015
- Re: [Coq-Club] Newbies Question, Pierre Courtieu, 05/22/2015
- RE: [Coq-Club] Newbies Question, FOURNIER Laurent, 05/26/2015
