coq-club - Re: [Coq-Club] proofs involving 'match' constructs
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] proofs involving 'match' constructs
  • Date: Fri, 29 May 2015 21:34:16 +0200
Hi,
This lemma is in fact (without help of some axioms) not provable in Coq. That said, here is a solution that uses an axiom (JMeq_eq). I explain the problem below.
Require Import Vector.
Require Import ArithRing.
Require Import Coq.Logic.JMeq.
Program Fixpoint ScatHUnion_0 {A} {n:nat} (pad:nat): t A n -> t (option A) ((S pad)*n) :=
 match n return (t A n) -> (t (option A) ((S pad)*n)) with
 | 0 => fun _ => @nil (option A)
 | S p => fun a => cons _ (Some (hd a)) _ (append (const None pad) (ScatHUnion_0 pad (tl a)))
 end.
Next Obligation.
 ring.
Defined.
Lemma test0: @ScatHUnion_0 nat 0 0 (@nil nat) = (@nil (option nat)).
Proof.
  cbv.
  generalize (mult_n_O 0); intros e.
  cbn in e.
At this point you will have:
  e : 0 = 0
   match e in (_ = y) return (t (option nat) y) with
   | eq_refl => nil (option nat)
   end = nil (option nat)
As you see the problem now would be solved if we could just replace e with eq_refl (i.e., destruct e.)
This is impossible though. This is because doing a case analysis on e would require us to consider
the general case where e is replaced by e’ : 0 = x for a general x. This on the other makes the goal
ill-typed.
The problem boils down to the fact that in coq you can’t prove unicity of identity proofs (or any other axiom equivalent
to it, e.g., JMeq_eq I used).
Using JMeq_eq changes eq to JMeq which due to its heterogeneity does not become ill-typed under
such an abstraction as above.
  apply JMeq_eq.
  destruct e.
  trivial.
Qed.
Here is a short Coq script proving equivalence of some axioms that are equivalent to UIP (unicity of identity proof) and JMeq_eq:
https://gist.github.com/amintimany/798a096e2f2ff0582b36
Regards,
Amin
On 29 May 2015, at 20:21, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
I am wondering what is a good approach to trying to prove some things like this:
 end.
Next Obligation.
 ring.
Defined.
(This definition works only under Coq 8.5. Under 8.4 I had to define it differently).
I stuck proving the following trivial lemma:
I could not get much further than:
test0 < compute.
1 subgoal
  match mult_n_O 0 in (_ = y) return (t (option nat) y) with
Any suggestions how to deal with proving constructs like this?
Thanks!
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
