coq-club - Re: [Coq-Club] proofs involving 'match' constructs
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] proofs involving 'match' constructs
  • Date: Fri, 29 May 2015 17:24:27 -0400
The key to this proof is that the equality you're matching on must take the form of [0 = z] for any [z : nat].  The insight is that it's possible to generalize [nil] to a term of type [t (option nat) z] that is judgmentally [nil] when [z] is judgmentally 0 (what it is on the other values of [z] is irrelevant).
On Fri, May 29, 2015 at 5:13 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Here's a shorter, more ad-hoc, proof:
Require Import Vector.
Require Import ArithRing.
Goal match mult_n_O 0 in (_ = y) return (t (option nat) y) with
   | eq_refl => nil (option nat)
   end = nil (option nat).
Proof.
  generalize (mult_n_O 0).
  simpl.
  set (z := 0) at 2.
  change (nil (option nat)) with (Vector.const (@None nat) z) at 2.
  change 0 with z at 2.
  clearbody z.
  intros []; reflexivity.
Defined.
On Fri, May 29, 2015 at 3:53 PM, Amin <amintimany AT gmail.com> wrote:
Oh wait, It seems I haven’t been paying close enough attention. In this case as e is equality over type nat, UIP does in fact hold for it (as equality for nat is decidable) and thus we can prove this lemma as follows:
Require Import Coq.Logic.JMeq.
Require Import Coq.Arith.Peano_dec.
Program Fixpoint ScatHUnion_0 {A} {n:nat} (pad:nat): t A n -> t (option A) ((S pad)*n) :=
 match n return (t A n) -> (t (option A) ((S pad)*n)) with
 | 0 => fun _ => @nil (option A)
 | S p => fun a => cons _ (Some (hd a)) _ (append (const None pad) (ScatHUnion_0 pad (tl a)))
 end.
Next Obligation.
 ring.
Defined.
(* code from EqFacts.v in the gist link in the other email *)
Section Eq_Facts.
  Variable A : Type.
  Definition K := forall (x : A) (P : x = x -> Prop), P eq_refl -> forall (eq : x = x), P eq.
  Definition URIP := forall (x : A) (eq : x = x), eq = eq_refl.
  Definition UIP := forall (x y : A) (eq eq' : x = y), eq = eq'.
  Definition eq_rect_eq := forall (x : A) (P : A -> Type) (eq : x = x) (p : P x), p = eq_rect x P p x eq.
  Definition projT2_eq := forall (x : A) (P : A -> Type) (p q : P x), existT P x p = existT P x q -> p = q.
  Lemma K_URIP : K -> URIP.
  Proof.
    intros k x eq.
    apply (k _ (fun p => p = eq_refl) eq_refl).
  Qed.
  Lemma UIP_UIP : URIP -> UIP.
  Proof.
    intros urip x y eq eq'.
    destruct eq'.
    apply urip.
  Qed.
  Theorem UIP_eq_rect_eq : UIP -> eq_rect_eq.
  Proof.
    intros uip x P eq p.
    rewrite (uip _ _ eq eq_refl); trivial.
  Qed.
  Theorem eq_rect_eq_projT2_eq : eq_rect_eq -> projT2_eq.
  Proof.
    intros ere x P p q H.
    set (proj1_eq := fun (v : sigT P) (H : existT P x p = v) => match H in _ = z return projT1 (existT P x p) = projT1 z with eq_refl => eq_refl end).
    assert (H' : match (proj1_eq (existT P x q) H) in _ = u return P u with eq_refl => projT2 (existT P x p) end = projT2 (existT P x q)).
      destruct H; trivial.
    cbv in ere.
    rewrite <- (ere _ _ (proj1_eq _ H)) in H'; trivial.
  Qed.
  Theorem projT2_eq_k : projT2_eq -> K.
  Proof.
    intros p2 x P H eq.
    cut (eq = eq_refl); [intros H'; rewrite H'; trivial|].
    apply p2; destruct eq; trivial.
  Qed.
  Section Dec.
    Hypothesis A_dec : forall a b : A, {a = b} + {a <> b}.
    Definition make_eq {a b : A} (eq : a = b) : a = b.
    Proof.
      destruct (A_dec a b) as [H|H].
      + exact H.
      + exact (False_rect _ (H eq)).
    Defined.
    Theorem make_eq_const : forall {a b : A} (eq eq' : a = b), make_eq eq = make_eq eq'.
    Proof.
      intros a b eq eq'.
      cbv.
      destruct A_dec as [H|H]; trivial.
      destruct (H eq).
    Qed.
    Theorem make_eq_com_sym : forall {a b : A} (eq : a = b), eq_trans (eq_sym (make_eq (eq_refl a))) (make_eq eq) = eq.
    Proof.
      intros a b eq.
      destruct eq.
      destruct (make_eq eq_refl); trivial.
    Qed.
    Theorem k : K.
    Proof.
      intros x P H eq.
      rewrite <- make_eq_com_sym in H.
      rewrite <- make_eq_com_sym.
      replace (make_eq eq) with (make_eq (eq_refl x)); trivial.
      apply make_eq_const.
    Qed.
  End Dec.
End Eq_Facts.
(* End of code from EqFacts.v *)
Lemma URIP_nat : URIP nat.
Proof.
  apply K_URIP.
  apply k.
  apply eq_nat_dec.
Qed.
Lemma test0: @ScatHUnion_0 nat 0 0 (@nil nat) = (@nil (option nat)).
Proof.
  cbv.
  generalize (mult_n_O 0); intros e.
  cbn in e.
  rewrite (URIP_nat 0 e).
  trivial.
Qed.
On 29 May 2015, at 21:34, Amin <amintimany AT gmail.com> wrote:
Hi,
This lemma is in fact (without help of some axioms) not provable in Coq. That said, here is a solution that uses an axiom (JMeq_eq). I explain the problem below.
 end.
Next Obligation.
 ring.
Defined.
Proof.
  cbv.
  cbn in e.
At this point you will have:
  e : 0 = 0
   match e in (_ = y) return (t (option nat) y) with
As you see the problem now would be solved if we could just replace e with eq_refl (i.e., destruct e.)
This is impossible though. This is because doing a case analysis on e would require us to consider
the general case where e is replaced by e’ : 0 = x for a general x. This on the other makes the goal
ill-typed.
The problem boils down to the fact that in coq you can’t prove unicity of identity proofs (or any other axiom equivalent
to it, e.g., JMeq_eq I used).
Using JMeq_eq changes eq to JMeq which due to its heterogeneity does not become ill-typed under
such an abstraction as above.
  apply JMeq_eq.
  destruct e.
  trivial.
Qed.
Here is a short Coq script proving equivalence of some axioms that are equivalent to UIP (unicity of identity proof) and JMeq_eq:
Regards,
Amin
On 29 May 2015, at 20:21, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
I am wondering what is a good approach to trying to prove some things like this:
 end.
Next Obligation.
 ring.
Defined.
(This definition works only under Coq 8.5. Under 8.4 I had to define it differently).
I stuck proving the following trivial lemma:
I could not get much further than:
test0 < compute.
1 subgoal
Any suggestions how to deal with proving constructs like this?
Thanks!
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
