- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] proofs involving 'match' constructs
- Date: Fri, 29 May 2015 21:53:27 +0200
Oh wait, It seems I haven’t been paying close enough attention. In this case as e is equality over type nat, UIP does in fact hold for it (as equality for nat is decidable) and thus we can prove this lemma as follows:
Require Import Vector.
Require Import ArithRing.
Require Import Coq.Logic.JMeq.
Require Import Coq.Arith.Peano_dec.
Program Fixpoint ScatHUnion_0 {A} {n:nat} (pad:nat): t A n -> t (option A) ((S pad)*n) :=
match n return (t A n) -> (t (option A) ((S pad)*n)) with
| 0 => fun _ => @nil (option A)
| S p => fun a => cons _ (Some (hd a)) _ (append (const None pad) (ScatHUnion_0 pad (tl a)))
end.
Next Obligation.
ring.
Defined.
(* code from EqFacts.v in the gist link in the other email *)
Section Eq_Facts.
Variable A : Type.
Definition K := forall (x : A) (P : x = x -> Prop), P eq_refl -> forall (eq : x = x), P eq.
Definition URIP := forall (x : A) (eq : x = x), eq = eq_refl.
Definition UIP := forall (x y : A) (eq eq' : x = y), eq = eq'.
Definition eq_rect_eq := forall (x : A) (P : A -> Type) (eq : x = x) (p : P x), p = eq_rect x P p x eq.
Definition projT2_eq := forall (x : A) (P : A -> Type) (p q : P x), existT P x p = existT P x q -> p = q.
Lemma K_URIP : K -> URIP.
Proof.
intros k x eq.
apply (k _ (fun p => p = eq_refl) eq_refl).
Qed.
Lemma UIP_UIP : URIP -> UIP.
Proof.
intros urip x y eq eq'.
destruct eq'.
apply urip.
Qed.
Theorem UIP_eq_rect_eq : UIP -> eq_rect_eq.
Proof.
intros uip x P eq p.
rewrite (uip _ _ eq eq_refl); trivial.
Qed.
Theorem eq_rect_eq_projT2_eq : eq_rect_eq -> projT2_eq.
Proof.
intros ere x P p q H.
set (proj1_eq := fun (v : sigT P) (H : existT P x p = v) => match H in _ = z return projT1 (existT P x p) = projT1 z with eq_refl => eq_refl end).
assert (H' : match (proj1_eq (existT P x q) H) in _ = u return P u with eq_refl => projT2 (existT P x p) end = projT2 (existT P x q)).
destruct H; trivial.
cbv in ere.
rewrite <- (ere _ _ (proj1_eq _ H)) in H'; trivial.
Qed.
Theorem projT2_eq_k : projT2_eq -> K.
Proof.
intros p2 x P H eq.
cut (eq = eq_refl); [intros H'; rewrite H'; trivial|].
apply p2; destruct eq; trivial.
Qed.
Section Dec.
Hypothesis A_dec : forall a b : A, {a = b} + {a <> b}.
Definition make_eq {a b : A} (eq : a = b) : a = b.
Proof.
destruct (A_dec a b) as [H|H].
+ exact H.
+ exact (False_rect _ (H eq)).
Defined.
Theorem make_eq_const : forall {a b : A} (eq eq' : a = b), make_eq eq = make_eq eq'.
Proof.
intros a b eq eq'.
cbv.
destruct A_dec as [H|H]; trivial.
destruct (H eq).
Qed.
Theorem make_eq_com_sym : forall {a b : A} (eq : a = b), eq_trans (eq_sym (make_eq (eq_refl a))) (make_eq eq) = eq.
Proof.
intros a b eq.
destruct eq.
destruct (make_eq eq_refl); trivial.
Qed.
Theorem k : K.
Proof.
intros x P H eq.
rewrite <- make_eq_com_sym in H.
rewrite <- make_eq_com_sym.
replace (make_eq eq) with (make_eq (eq_refl x)); trivial.
apply make_eq_const.
Qed.
End Dec.
End Eq_Facts.
(* End of code from EqFacts.v *)
Lemma URIP_nat : URIP nat.
Proof.
apply K_URIP.
apply k.
apply eq_nat_dec.
Qed.
Lemma test0: @ScatHUnion_0 nat 0 0 (@nil nat) = (@nil (option nat)).
Proof.
cbv.
generalize (mult_n_O 0); intros e.
cbn in e.
rewrite (URIP_nat 0 e).
trivial.
Qed.
On 29 May 2015, at 21:34, Amin <amintimany AT gmail.com> wrote:Hi,This lemma is in fact (without help of some axioms) not provable in Coq. That said, here is a solution that uses an axiom (JMeq_eq). I explain the problem below.
Require Import Vector.Require Import ArithRing.Require Import Coq.Logic.JMeq.Program Fixpoint ScatHUnion_0 {A} {n:nat} (pad:nat): t A n -> t (option A) ((S pad)*n) :=match n return (t A n) -> (t (option A) ((S pad)*n)) with| 0 => fun _ => @nil (option A)| S p => fun a => cons _ (Some (hd a)) _ (append (const None pad) (ScatHUnion_0 pad (tl a)))end.Next Obligation.ring.Defined.Lemma test0: @ScatHUnion_0 nat 0 0 (@nil nat) = (@nil (option nat)).Proof.cbv.generalize (mult_n_O 0); intros e.cbn in e.(*At this point you will have:e : 0 = 0============================match e in (_ = y) return (t (option nat) y) with| eq_refl => nil (option nat)end = nil (option nat)As you see the problem now would be solved if we could just replace e with eq_refl (i.e., destruct e.)This is impossible though. This is because doing a case analysis on e would require us to considerthe general case where e is replaced by e’ : 0 = x for a general x. This on the other makes the goalill-typed.The problem boils down to the fact that in coq you can’t prove unicity of identity proofs (or any other axiom equivalentto it, e.g., JMeq_eq I used).Using JMeq_eq changes eq to JMeq which due to its heterogeneity does not become ill-typed undersuch an abstraction as above.*)apply JMeq_eq.destruct e.trivial.Qed.Here is a short Coq script proving equivalence of some axioms that are equivalent to UIP (unicity of identity proof) and JMeq_eq:Regards,AminOn 29 May 2015, at 20:21, Vadim Zaliva <vzaliva AT cmu.edu> wrote:I am wondering what is a good approach to trying to prove some things like this:
end.
Next Obligation.
ring.
Defined.
(This definition works only under Coq 8.5. Under 8.4 I had to define it differently).
I stuck proving the following trivial lemma:
I could not get much further than:
test0 < compute.
1 subgoal
match mult_n_O 0 in (_ = y) return (t (option nat) y) with
Any suggestions how to deal with proving constructs like this?
Thanks!
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] proofs involving 'match' constructs, Vadim Zaliva, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Amin, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Jason Gross, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Laurent Théry, 05/29/2015
