coq-club - Re: [Coq-Club] Is it possible to rewrite under binders?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Is it possible to rewrite under binders?
  • Date: Wed, 27 Jan 2016 17:51:59 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f52.google.com
  • Ironport-phdr: 9a23:0OdyEhHZb2Td6ZOCF4g98p1GYnF86YWxBRYc798ds5kLTJ75pMWwAkXT6L1XgUPTWs2DsrQf27WQ6/urATZIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbqoNaLOU1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4+VWMfjhpBBUDh4RDkU5Ht+n/4sex82ySeMMDeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
On 01/27/2016 05:22 PM, Guillaume Melquiond wrote:
On 27/01/2016 16:36, Jonathan Leivent wrote:
On 01/27/2016 03:39 AM, Thorsten Altenkirch wrote:
Indeed you need functional extensionality which isn’t provable in coq.
Imho this is a bug, but one which isn’t easy to fix.
Why would it be considered a bug? It is always possible to add the
functional extensionality axiom to Coq when needed. And, without it,
one can express concepts such as that two functions of the same type
where one sorts lists in O(N^2) time and the other in O(NlogN) time are
not identical.
I have always found this argument to be far-fetched. Indeed, complexity
and convertibility are two orthogonal concepts. So saying that two
functions with different complexity cannot be equal is nonsensical,
since they might well be convertible and thus trivially equal.
Best regards,
Guillaume
I am not saying that they cannot be equal, I am instead saying that it shouldn't be considered a Coq bug that they are not forced to be equal (or forced to be not equal). Just as it should not be considered a Coq bug that proofs are not forced to be irrelevant (or forced to be relevant). Or that excluded middle is not part of the logic. In other words, it is a feature of Coq that its logic is weak enough to encompass many useful additions by axioms, yet permit usage without those axioms. I honestly did not think this was the least bit controversial.
Certainly, it would be nice to have guarantees that use of certain axioms does not lead to inconsistency. I suggested an enhanced version of something like Print Assumptions on coqdev once just to help with this purpose (assert that a development uses only certain axioms or combinations of axioms that are considered consistent together).
-- Jonathan
