coq-club - Re: [Coq-Club] Is it possible to rewrite under binders?
  • From: Guillaume Brunerie <guillaume.brunerie AT gmail.com>
  • To: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Is it possible to rewrite under binders?
  • Date: Thu, 28 Jan 2016 19:39:41 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=guillaume.brunerie AT gmail.com; spf=Pass smtp.mailfrom=guillaume.brunerie AT gmail.com; spf=None smtp.helo=postmaster AT mail-lb0-f177.google.com
  • Ironport-phdr: 9a23:NVhv5BboHU+DyPmCWhZjn4n/LSx+4OfEezUN459isYplN5qZpcW6bnLW6fgltlLVR4KTs6sC0LqJ9fi8EjVZvN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcWPKFwR2XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGY2zRakzTKRZATI6KCh1oZSz7ViQBTeIs1AbSyA9lgdCSyPB8RuyCpz2q27xsvd38CicJ8z/C74uD2eM9aBuHTD1iSMDPiM8/Sn9kNF2gbharVr1qAF+x4rdfYSYcvBkY6XQZ9IXbWVEV8dVESdGB9XvPMM0E+MdMLMA/MHGrFwUoE77XFH0CQ==
What about the following two functions (in mathematical notation)?
f : N -> N
f(n) = 0
g : N -> N
g(n) = 10^10 - 10^10
They are definitionally equal, yet I assume that after extraction f
will run much faster than g unless the extraction process optimizes
the definition of g (actually, looking at the doc it seems that it
does optimize g, but the command "Unset Extraction Optimize" disables
this optimization. It’s kind of cheating to optimize g :-) )
2016-01-28 18:11 GMT+01:00 Jonathan Leivent
<jonikelee AT gmail.com>:
> On 01/28/2016 11:58 AM, Guillaume Melquiond wrote:
>> On 28/01/2016 17:15, Jonathan Leivent wrote:
>>> If the output of extraction
>>> from two extensionally-equivalent functions would behave differently in
>>> OCaml, then I would prefer that they are not treated within Coq as
>>> substitutionally identical.
>> But that is already the case, even without any functional extensionality!
>> Axiom g : nat -> nat -> nat.
>> Fixpoint f1 (n : nat) :=
>> match n with S n => g (f1 n) (f1 n) | O => g O O end.
>> Fixpoint f2 (n : nat) :=
>> match n with S n => let v := f2 n in g v v | O => g O O end.
>> Goal f1 = f2. reflexivity. Qed.
>> While f1 and f2 are convertible, their behavior is entirely different
>> when extracted to Ocaml. One performs an exponential number of calls to
>> g, the other one is only linear. Sure, you could devise an Ocaml
>> optimization so that f1 also has linear complexity once compiled. But
>> where do you set the limit of what a compiler is allowed to?
>> Best regards,
>> Guillaume
> What's funny about this is that initially in my reply I had the
> parenthetical "(modulo reduction)", and then removed it just before hitting
> send ;)
> -- Jonathan
