coq-club - Re: [Coq-Club] Doubt about In (and refine)
  • From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Doubt about In (and refine)
  • Date: Thu, 25 Feb 2016 12:28:29 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jean-francois.monin AT imag.fr; spf=Neutral smtp.mailfrom=jean-francois.monin AT imag.fr; spf=None smtp.helo=postmaster AT furon.ujf-grenoble.fr
  • Ironport-phdr: 9a23:jR80wRU018oHBn60+SkLEJGeOn7V8LGtZVwlr6E/grcLSJyIuqrYZhGHt8tkgFKBZ4jH8fUM07OQ6PC/HzJYqszR+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8KVPV0D3mr1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDsBdBBU3r9hj8VZDwqWPfsex83mHOP8D/S/U6Qz2k5KBqU1ntjyEGMRY49WjYzMJq2vEI6Cm9rgByltaHKLqeM+BzK/vQ
Hello Saul,
I don't resist to share another short version, using a handcrafted
inversion technique published at ITP'13 (originally called "small
inversions").
It can first be used on your previous problem for getting an element in a
sequence implemented by a binary balanced tree.
Inductive Sequence (E:Set) : nat -> Set :=
| SequenceLeaf: E -> E -> Sequence E 0
| SequenceNode: forall n, Sequence E n -> Sequence E n -> Sequence E (S n).
(* Get premises, following ITP13 paper *)
Definition pr_Sequence {E} {n} (s : Sequence E n) :=
let diag n :=
match n with
| 0 => forall X: Type, (E -> E -> X) -> X
| S n => forall X: Type, (Sequence E n -> Sequence E n -> X) -> X
end in
match s in Sequence _ n return diag n with
| SequenceLeaf e0 e1 => fun X k => k e0 e1
| SequenceNode m s0 s1 => fun X k => k s0 s1
end.
Inductive List (E:Set) : nat -> Set :=
| ListLeaf: E -> List E 0
| ListNode: forall n, E -> List E n -> List E (S n).
Inductive Digit := D0 | D1.
Fixpoint get {E : Set} {n : nat} (ds: List Digit n) : Sequence E n -> E :=
match ds in (List _ n0) return (Sequence E n0 -> E) with
| ListLeaf D0 => fun t => pr_Sequence t E (fun e0 e1 => e0)
| ListLeaf D1 => fun t => pr_Sequence t E (fun e0 e1 => e1)
| ListNode x D0 l => fun t => pr_Sequence t E (fun s0 s1 => get l s0)
| ListNode x D1 l => fun t => pr_Sequence t E (fun s0 s1 => get l s1)
end.
Now back to testing equality on List n, we need
- injectivity of ListLeaf: Coq built-in injection works
- injectivity of ListNode: an application of pr_List similar to pr_Sequence
- a more general version called pr_List'
Definition pr_List {E n} (s : List E n) :=
let diag n :=
match n with
| 0 => forall X: Type, (E -> X) -> X
| S n => forall X: Type, (E -> List E n -> X) -> X
end in
match s in List _ n return diag n with
| ListLeaf e => fun X k => k e
| ListNode m e s => fun X k => k e s
end.
(* More general version *)
(* To be used when the goal depends on the destructed list *)
Definition pr_List' {E n} (s : List E n) :=
let diag n :=
match n return List E n -> Type with
| 0 => fun s => forall X: List E 0 -> Type,
(forall e, X (ListLeaf E e)) -> X s
| S p => fun s => forall X: List E (S p) -> Type,
(forall e l, X (ListNode E p e l)) -> X s
end in
match s in List _ n return diag n s with
end.
(* Injectivity of ListNode as an application of pr_List *)
Lemma inj_ListNode {E n a b u v} :
ListNode E n a u = ListNode E n b v ->
forall X: Prop, (a = b -> u = v -> X) -> X.
Proof.
intros e X.
change (pr_List (ListNode E n a u) _ (fun x y => (x = b -> y = v -> X) ->
X)).
rewrite e; red. intro k. apply k; reflexivity.
Qed.
Definition Digit_dec : forall c d: Digit, {c = d} + {c <> d}.
Proof.
destruct c; destruct d; (left; reflexivity) || (right; discriminate).
Defined.
Definition list_digit_dec:
forall n (cs ds: List Digit n), {cs = ds} + {cs <> ds}.
Proof.
intros n cs.
induction cs as [c | n c cs Hcs]; intro ds; apply (pr_List' ds); clear ds.
- intro d; destruct (Digit_dec c d) as [ e | ne ].
+ left; congruence.
+ right; intro e. injection e; congruence.
- intros d ds; destruct (Digit_dec c d) as [ e | ne ].
+ destruct (Hcs ds) as [es | nes].
* left; congruence.
* right; intro es. apply (inj_ListNode es). congruence.
+ right; intro es. apply (inj_ListNode es). congruence.
Defined.
Best,
Jean-Francois
On Wed, Feb 24, 2016 at 09:00:10AM -0300, Saulo Araujo wrote:
> Hi Dominique,
> Thanks a lot for providing this shorter proof. I am going to study it
> with
> care so that I can apply similar techniques in other dependent type
> equalitity decidability proofs.
> Sincerely,
> Saulo
