coq-club - Re: [Coq-Club] Doubt about In (and refine)
  • From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Doubt about In (and refine)
  • Date: Thu, 25 Feb 2016 18:00:42 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jean-francois.monin AT imag.fr; spf=Neutral smtp.mailfrom=jean-francois.monin AT imag.fr; spf=None smtp.helo=postmaster AT amazone.ujf-grenoble.fr
  • Ironport-phdr: 9a23:m1OqvhEsGpLPKClPl09TXJ1GYnF86YWxBRYc798ds5kLTJ75osywAkXT6L1XgUPTWs2DsrQf27WQ7fmrBDxIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbsotaOM01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4+X2wQ1zRSCg7O6xDhFrL2tCr8/r5/1SCceMPsRLY/XjW5qaJsTh7uoCYCPjF//nuB2Z84t75SvB/0/083+IXTeozAbPc=
This one is better:
http://www-verimag.imag.fr/~monin/Publis/itp13.pdf
Sincerely,
JF
On Thu, Feb 25, 2016 at 09:03:43AM -0300, Saulo Araujo wrote:
> Hi Jean-Francois,
> I am glad you couldn't help but send another proof :)
> Is [1]http://www-verimag.imag.fr/~monin/Proof/SmallInvScalesUp/paper.pdf
> the paper that you mentioned?
> Sincerely,
> Saulo
> On Thu, Feb 25, 2016 at 8:28 AM, Jean-Francois Monin
> <[2]jean-francois.monin AT imag.fr>
> wrote:
> Hello Saul,
> I don't resist to share another short version, using a handcrafted
> inversion technique published at ITP'13 (originally called "small
> inversions").
> It can first be used on your previous problem for getting an element in
> a
> sequence implemented by a binary balanced tree.
> Inductive Sequence (E:Set) : nat -> Set :=
>  | SequenceLeaf: E -> E -> Sequence E 0
>  | SequenceNode: forall n, Sequence E n -> Sequence E n -> Sequence E
> (S
> n).
> (* Get premises, following ITP13 paper *)
> Definition pr_Sequence {E} {n} (s : Sequence E n) :=
>   let diag n :=
>       match n with
>         | 0 => forall X: Type, (E -> E -> X) -> X
>         | S n => forall X: Type, (Sequence E n -> Sequence E n -> X) ->
> X
>       end in
>   match s in Sequence _ n return diag n with
>     | SequenceLeaf e0 e1 => fun X k => k e0 e1
>     | SequenceNode m s0 s1 => fun X k => k s0 s1
>   end.
> Inductive List (E:Set) : nat -> Set :=
>  | ListLeaf: E -> List E 0
>  | ListNode: forall n, E -> List E n -> List E (S n).
> Inductive Digit :=  D0 | D1.
> Fixpoint get {E : Set} {n : nat} (ds: List Digit n) : Sequence E n -> E
>   match ds in (List _ n0) return (Sequence E n0 -> E) with
>     | ListLeaf D0 => fun t => pr_Sequence t E (fun e0 e1 => e0)
>     | ListLeaf D1 => fun t => pr_Sequence t E (fun e0 e1 => e1)
>     | ListNode x D0 l => fun t => pr_Sequence t E (fun s0 s1 => get l
> s0)
>     | ListNode x D1 l => fun t => pr_Sequence t E (fun s0 s1 => get l
> s1)
>    end.
> Now back to testing equality on List n, we need
> - injectivity of ListLeaf: Coq built-in injection works
> - injectivity of ListNode: an application of pr_List similar to
> pr_Sequence
> - a more general version called pr_List'
> Definition pr_List {E n} (s : List E n) :=
>   let diag n :=
>       match n with
>         | 0 => forall X: Type, (E -> X) -> X
>         | S n => forall X: Type, (E -> List E n -> X) -> X
>       end in
>   match s in List _ n return diag n with
>     | ListLeaf e => fun X k => k e
>     | ListNode m e s => fun X k => k e s
>   end.
> (* More general version *)
> (* To be used when the goal depends on the destructed list *)
> Definition pr_List' {E n} (s : List E n) :=
>   let diag n :=
>       match n return List E n -> Type with
>         | 0 => fun s => forall X: List E 0 -> Type,
>                (forall e, X (ListLeaf E e)) -> X s
>         | S p => fun s => forall X: List E (S p) -> Type,
>                  (forall e l, X (ListNode E p e l)) -> X s
>       end in
>   match s in List _ n return diag n s with
>   end.
> (* Injectivity of ListNode as an application of pr_List *)
> Lemma inj_ListNode {E n a b u v} :
>    ListNode E n a u = ListNode E n b v ->
>    forall X: Prop, (a = b -> u = v -> X) -> X.
> Proof.
>   intros e X.
>   change (pr_List (ListNode E n a u) _ (fun x y => (x = b -> y = v ->
> X)
> -> X)).
>   rewrite e; red. intro k. apply k; reflexivity.
> Qed.
> Definition Digit_dec : forall c d: Digit, {c = d} + {c <> d}.
> Proof.
>   destruct c; destruct d; (left; reflexivity) || (right; discriminate).
> Defined.
> Definition list_digit_dec:
>    forall n (cs ds: List Digit n), {cs = ds} + {cs <> ds}.
> Proof.
> intros n cs.
> induction cs as [c | n c cs Hcs]; intro ds; apply (pr_List' ds); clear
> ds.
> - intro d; destruct (Digit_dec c d) as [ e | ne ].
>   + left; congruence.
>   + right; intro e. injection e; congruence.
> - intros d ds; destruct (Digit_dec c d) as [ e | ne ].
>   + destruct (Hcs ds) as [es | nes].
>     * left; congruence.
>     * right; intro es. apply (inj_ListNode es). congruence.
>   + right; intro es. apply (inj_ListNode es). congruence.
> Defined.
> Best,
> Jean-Francois
> On Wed, Feb 24, 2016 at 09:00:10AM -0300, Saulo Araujo wrote:
> >    Hi Dominique,
> >    Thanks a lot for providing this shorter proof. I am going to study
> it with
> >    care so that I can apply similar techniques in other dependent
> type
> >    equalitity decidability proofs.
> >    Sincerely,
> >    Saulo
