coq-club - Re: [Coq-Club] Prove associativity of composition of relations
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Prove associativity of composition of relations
  • Date: Thu, 12 May 2016 12:09:21 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f173.google.com
  • Ironport-phdr: 9a23:eKNHZxQNTgfufE/x2eedpdZXNdpsv+yvbD5Q0YIujvd0So/mwa64YRyN2/xhgRfzUJnB7Loc0qyN4/GmAD1LsMvJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuKMk4Z2XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmp9sMbsrFzISRaFznoaSGQf1BRSVVvr9hb/C777sirhtud+kACcNMv6BeQ9UzSj9KdmS1nhji4BO3g48X3YosN1haNf5hmmokoskMbvfIiJOa8mLevmdtQASD8ZUw==
Your intuition about = (Coq.Init.Logic.eq) is/was too rosy.
For 2 closed terms, say a and b, the only time you can prove a=b is when the strong normal forms of a and b are SYNTACTICALLY the same.
When you instantiate your lemma with P Q R := eq nat, the LHS and RHS are closed terms in strong normal form, and they are NOT syntactically the same.
Hence your lemma is not provable.
-- Abhishek
http://www.cs.cornell.edu/~aa755/
On Wed, May 11, 2016 at 1:07 PM, scott constable <sdconsta AT syr.edu> wrote:
> Correction: "I think it should be possible to prove associativity of my definition of composition"...
> On Wed, May 11, 2016 at 1:06 PM, scott constable <sdconsta AT syr.edu> wrote:
>> Thanks for the quick response Frédéric, but I already have a large project which relies heavily on my definition of composition, and the CoLoR library uses a different definition of composition. Hence I would have to rework a lot of my project to fit the CoLoR definition. I think it should be possible to prove associativity of my definition of relation in Coq, and I would like to know how to do so.
>> ~Scott
>> On Wed, May 11, 2016 at 1:00 PM, Frédéric Blanqui <frederic.blanqui AT inria.fr> wrote:
>>> Hello. You will find useful developments on relations in CoLoR.Util.RelUtil.v (coq-color on opam). See http://color.inria.fr/doc/CoLoR.Util.Relation.RelUtil.html for the definitions and theorems without the proofs. Best regards, Frédéric.
>>> Le 11/05/2016 18:51, scott constable a écrit :
>>>> Hi All,
>>>> I have the following definition of composition:
>>>> Inductive Compose : T → V → Prop :=
>>>> | comp_intro : ∀ x y z, R1 x y → R2 y z → Compose x z.
>>>> Notation "P ∘ R" := (Compose R P) (at level 55, right associativity).
>>>> And I am hopelessly lost as to how to prove this theorem:
>>>> Lemma compose_assoc : ∀ (R : U → V → Prop) (Q : V → T → Prop)
>>>>                           (P : T → W → Prop), P ∘ Q ∘ R = (P ∘ Q) ∘ R.
>>>> Any help would be extremely appreciated!
>>>> Thanks in advance,
>>>> ~Scott Constable
