coq-club - Re: [Coq-Club] Prove associativity of composition of relations
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Prove associativity of composition of relations
  • Date: Wed, 11 May 2016 17:10:42 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=fkunze AT fakusb.de; spf=None smtp.mailfrom=fkunze AT fakusb.de; spf=None smtp.helo=postmaster AT tucana.uberspace.de
  • Ironport-phdr: 9a23:tUkqCxIYeXrdute6u9mcpTZWNBhigK39O0sv0rFitYgUKfjxwZ3uMQTl6Ol3ixeRBMOAu6MC0rSd6vi7EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35Xxjr75osWIKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs1UVWGQflFJrHg7X4VmuUJTstDn3nuR02zSBN4v6QOZnCnyZ8653RUqw2288PDkj/TSPhw==
Hello Scott,
I'm pretty sure that, without additional axioms, you will just be able to prove "<->" instead of equality, e. g. "P ∘ Q ∘ R <-> (P ∘ Q) ∘ R."
Does this suffice?
Best,
Fabian
scott constable <sdconsta AT syr.edu> schrieb am Mi., 11. Mai 2016 19:07:
Correction: "I think it should be possible to prove associativity of my definition of composition"...
On Wed, May 11, 2016 at 1:06 PM, scott constable <sdconsta AT syr.edu> wrote:
Thanks for the quick response Frédéric, but I already have a large project which relies heavily on my definition of composition, and the CoLoR library uses a different definition of composition. Hence I would have to rework a lot of my project to fit the CoLoR definition. I think it should be possible to prove associativity of my definition of relation in Coq, and I would like to know how to do so.
~Scott
On Wed, May 11, 2016 at 1:00 PM, Frédéric Blanqui <frederic.blanqui AT inria.fr> wrote:
Hello. You will find useful developments on relations in CoLoR.Util.RelUtil.v (coq-color on opam). See http://color.inria.fr/doc/CoLoR.Util.Relation.RelUtil.html for the definitions and theorems without the proofs. Best regards, Frédéric.
Le 11/05/2016 18:51, scott constable a écrit :
Hi All,
I have the following definition of composition:
Inductive Compose : T → V → Prop :=
| comp_intro : ∀ x y z, R1 x y → R2 y z → Compose x z.
Notation "P ∘ R" := (Compose R P) (at level 55, right associativity).
And I am hopelessly lost as to how to prove this theorem:
Lemma compose_assoc : ∀ (R : U → V → Prop) (Q : V → T → Prop)
                          (P : T → W → Prop), P ∘ Q ∘ R = (P ∘ Q) ∘ R.
Any help would be extremely appreciated!
Thanks in advance,
~Scott Constable
