- From: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Prove associativity of composition of relations
- Date: Thu, 12 May 2016 08:17:33 +0000
- Accept-language: en-US, en-GB
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.mailfrom=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.helo=postmaster AT uidappmx05.nottingham.ac.uk
- Ironport-phdr: 9a23:txilNRBUARdeioLPzER5UyQJP3N1i/DPJgcQr6AfoPdwSP7zpsbcNUDSrc9gkEXOFd2CrakU2qyP4+uxASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTmkbnisMyLKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvCwdKMhCLdcET4OMmYv5cStuwOJBV+E4WJZWWELmDJJBRLE5Vf0RMGinDH9s79B2C6AJtH7S/gdXSiv6aRqUhTowHM7Nzkj633ajIpZiL5WphGgvRd/64jTfJ2UMvV+d6abdNhcWGkXDZUZbDBIHo7pN9hHNOEGJ+sN94Q=
Just a remark: propositional extensionality is a truncated (to –1) version of univalence (from Homotopy Type Theory).
T.
From: <coq-club-request AT inria.fr> on behalf of scott constable <sdconsta AT syr.edu>
Reply-To: "coq-club AT inria.fr" <coq-club AT inria.fr>
Date: Wednesday, 11 May 2016 at 19:05
Ah, I think that propositional extensionality is the missing piece that I was looking for. Here is the complete solution:
Require Import FunctionalExtensionality.
Set Implicit Arguments.
Section Rels.
Variables T U V : Type.
Variable R1 : T -> U -> Prop.
Variable R2 : U -> V -> Prop.
Inductive Compose : T -> V -> Prop :=
| comp_intro : forall x y z, R1 x y -> R2 y z -> Compose x z.
End Rels.
Notation "R2 @ R1" := (Compose R1 R2) (at level 55, right associativity).
Axiom prop_ext : forall (P Q : Prop), (P <-> Q) -> P = Q.
Section RelLemmas.
Variables T U V W : Type.
Variable R3 : V -> W -> Prop.
Lemma compose_assoc : R3 @ R2 @ R1 = (R3 @ R2) @ R1.
Proof.
extensionality x; extensionality y.
apply prop_ext; split; intro H;
repeat match goal with
| [ H : (_ @ _) _ _ |- _ ] => inversion_clear H; subst
end; eauto using Compose.
Qed.
End RelLemmas.
Section Rels.
End Rels.
Section RelLemmas.
Proof.
Qed.
End RelLemmas.
Thanks so much everyone!
~Scott Constable
On Wed, May 11, 2016 at 1:47 PM, Cyprien Mangin <cyprien.mangin AT m4x.org> wrote:
> You need a form of predicate extensionality:
> forall (T U : Type) (P Q : T -> U -> Prop), (forall x y, P x y <-> Q x y) -> P = Q
> As remarked in https://coq.inria.fr/cocorico/CoqAndAxioms, this is entailed by propositional extensionality + functional extensionality.
> On Wed, May 11, 2016 at 7:36 PM, scott constable <sdconsta AT syr.edu> wrote:
>> Hi Cyprien,
>> I realize that I can prove an IFF, but what I really need for my theorems is a Leibniz equality. I tried functional extensionality without any success. I'm not sure what other types of extensionality would be applicable.
>> ~Scott
>> On Wed, May 11, 2016 at 1:32 PM, Cyprien Mangin <cyprien.mangin AT m4x.org> wrote:
>>> Hello,
>>> You will need some kind of extensionality to prove exactly your lemma. What you can prove is the following:
>>> ∀ (R : U → V → Prop) (Q : V → T → Prop) (P : T → W → Prop) x y, (P ∘ Q ∘ R) x y ↔ ((P ∘ Q) ∘ R) x y.
>>> Cyprien
>>> On Wed, May 11, 2016 at 7:07 PM, scott constable <sdconsta AT syr.edu> wrote:
>>>> Correction: "I think it should be possible to prove associativity of my definition of composition"...
>>>> On Wed, May 11, 2016 at 1:06 PM, scott constable <sdconsta AT syr.edu> wrote:
>>>>> Thanks for the quick response Frédéric, but I already have a large project which relies heavily on my definition of composition, and the CoLoR library uses a different definition of composition. Hence I would have to rework a lot of my project to fit the CoLoR definition. I think it should be possible to prove associativity of my definition of relation in Coq, and I would like to know how to do so.
>>>>> ~Scott
>>>>> On Wed, May 11, 2016 at 1:00 PM, Frédéric Blanqui <frederic.blanqui AT inria.fr> wrote:
>>>>>> Hello. You will find useful developments on relations in CoLoR.Util.RelUtil.v (coq-color on opam). See http://color.inria.fr/doc/CoLoR.Util.Relation.RelUtil.html for the definitions and theorems without the proofs. Best regards, Frédéric.
>>>>>> Le 11/05/2016 18:51, scott constable a écrit :
>>>>>>> Hi All,
>>>>>>> I have the following definition of composition:
>>>>>>> Inductive Compose : T → V → Prop :=
>>>>>>> | comp_intro : ∀ x y z, R1 x y → R2 y z → Compose x z.
>>>>>>> Notation "P ∘ R" := (Compose R P) (at level 55, right associativity).
>>>>>>> And I am hopelessly lost as to how to prove this theorem:
>>>>>>> Lemma compose_assoc : ∀ (R : U → V → Prop) (Q : V → T → Prop)
>>>>>>> (P : T → W → Prop), P ∘ Q ∘ R = (P ∘ Q) ∘ R.
>>>>>>> Any help would be extremely appreciated!
>>>>>>> Thanks in advance,
>>>>>>> ~Scott Constable
>> Hi Cyprien,
>> ~Scott
>>> Hello,
>>> Cyprien
>>>>> ~Scott
>>>>>>> Hi All,
>>>>>>> Thanks in advance,
>>>>>>> ~Scott Constable
This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please send it back to me, and immediately delete it. Please do not use, copy or disclose the information contained in this message or in any attachment. Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham. This message has been checked for viruses but the contents of an attachment may still contain software viruses which could damage your computer system, you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club] Prove associativity of composition of relations, scott constable, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Frédéric Blanqui, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, scott constable, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Fabian Kunze, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Cyprien Mangin, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Thorsten Altenkirch, 05/12/2016
- Re: [Coq-Club] Prove associativity of composition of relations, John Wiegley, 05/12/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Abhishek Anand, 05/12/2016
