- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Prove associativity of composition of relations
- Date: Wed, 11 May 2016 13:34:59 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sdconsta AT syr.edu; spf=None smtp.mailfrom=sdconsta AT syr.edu; spf=None smtp.helo=postmaster AT smtp1.syr.edu
- Ironport-phdr: 9a23:vFrKdRBYWwz/ocDeg1eDUyQJP3N1i/DPJgcQr6AfoPdwSP74oMbcNUDSrc9gkEXOFd2CrakU2qyP7eu5ATJIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/nhqbrpdaKO1sArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq8/VPlTCCksG2Ez/szi8xfZHiWV4X5JSW4RjgYACA/D9w3zVJP8+n/huuF63jKGNOXtXKpyVDi/ufQ4ACT0gTsKYmZquFrcjdZ92fpW
For reference, here is a more complete example of the problem I am facing:
Set Implicit Arguments.
Section Rels.
Variables T U V : Type.
Variable R1 : T -> U -> Prop.
Variable R2 : U -> V -> Prop.
Inductive Compose : T -> V -> Prop :=
| comp_intro : forall x y z, R1 x y -> R2 y z -> Compose x z.
End Rels.
Notation "R2 @ R1" := (Compose R1 R2) (at level 55, right associativity).
Section RelLemmas.
Variables T U V W : Type.
Variable R3 : V -> W -> Prop.
Lemma compose_assoc : R3 @ R2 @ R1 = (R3 @ R2) @ R1.
Proof. ???
Admitted.
End RelLemmas.
~Scott
On Wed, May 11, 2016 at 1:07 PM, scott constable <sdconsta AT syr.edu> wrote:
> Correction: "I think it should be possible to prove associativity of my definition of composition"...
> On Wed, May 11, 2016 at 1:06 PM, scott constable <sdconsta AT syr.edu> wrote:
>> Thanks for the quick response Frédéric, but I already have a large project which relies heavily on my definition of composition, and the CoLoR library uses a different definition of composition. Hence I would have to rework a lot of my project to fit the CoLoR definition. I think it should be possible to prove associativity of my definition of relation in Coq, and I would like to know how to do so.
>> ~Scott
>> On Wed, May 11, 2016 at 1:00 PM, Frédéric Blanqui <frederic.blanqui AT inria.fr> wrote:
>>> Hello. You will find useful developments on relations in CoLoR.Util.RelUtil.v (coq-color on opam). See http://color.inria.fr/doc/CoLoR.Util.Relation.RelUtil.html for the definitions and theorems without the proofs. Best regards, Frédéric.
>>> Le 11/05/2016 18:51, scott constable a écrit :
>>>> Hi All,
>>>> I have the following definition of composition:
>>>> Inductive Compose : T → V → Prop :=
>>>> | comp_intro : ∀ x y z, R1 x y → R2 y z → Compose x z.
>>>> Notation "P ∘ R" := (Compose R P) (at level 55, right associativity).
>>>> And I am hopelessly lost as to how to prove this theorem:
>>>> Lemma compose_assoc : ∀ (R : U → V → Prop) (Q : V → T → Prop)
>>>> (P : T → W → Prop), P ∘ Q ∘ R = (P ∘ Q) ∘ R.
>>>> Any help would be extremely appreciated!
>>>> Thanks in advance,
>>>> ~Scott Constable
Section Rels.
End Rels.
Section RelLemmas.
Proof. ???
Admitted.
End RelLemmas.
~Scott
>> ~Scott
>>>> Hi All,
>>>> Thanks in advance,
>>>> ~Scott Constable
- Re: [Coq-Club] Prove associativity of composition of relations, (continued)
- Re: [Coq-Club] Prove associativity of composition of relations, Frédéric Blanqui, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, scott constable, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Fabian Kunze, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Cyprien Mangin, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Thorsten Altenkirch, 05/12/2016
- Re: [Coq-Club] Prove associativity of composition of relations, John Wiegley, 05/12/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Abhishek Anand, 05/12/2016
