- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Prove associativity of composition of relations
- Date: Wed, 11 May 2016 13:07:29 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sdconsta AT syr.edu; spf=None smtp.mailfrom=sdconsta AT syr.edu; spf=None smtp.helo=postmaster AT smtp1.syr.edu
- Ironport-phdr: 9a23:kcJ9fxIpEUtgm74eTNmcpTZWNBhigK39O0sv0rFitYgUKfvxwZ3uMQTl6Ol3ixeRBMOAu6MC0rSd6vi4EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35Xxjr75osWLKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs2AXVXkK2hFPBRPZ5Rv+U9+lqSfxsexmxCCyJtzsC704RGLxvO9QVBb0hXJfZHYC+2bNh5kogQ==
Correction: "I think it should be possible to prove associativity of my definition of composition"...
On Wed, May 11, 2016 at 1:06 PM, scott constable <sdconsta AT syr.edu> wrote:
Thanks for the quick response Frédéric, but I already have a large project which relies heavily on my definition of composition, and the CoLoR library uses a different definition of composition. Hence I would have to rework a lot of my project to fit the CoLoR definition. I think it should be possible to prove associativity of my definition of relation in Coq, and I would like to know how to do so.~ScottOn Wed, May 11, 2016 at 1:00 PM, Frédéric Blanqui <frederic.blanqui AT inria.fr> wrote:Hello. You will find useful developments on relations in CoLoR.Util.RelUtil.v (coq-color on opam). See http://color.inria.fr/doc/CoLoR.Util.Relation.RelUtil.html for the definitions and theorems without the proofs. Best regards, Frédéric.
Le 11/05/2016 18:51, scott constable a écrit :
Hi All,
I have the following definition of composition:
Inductive Compose : T → V → Prop :=
| comp_intro : ∀ x y z, R1 x y → R2 y z → Compose x z.
Notation "P ∘ R" := (Compose R P) (at level 55, right associativity).
And I am hopelessly lost as to how to prove this theorem:
Lemma compose_assoc : ∀ (R : U → V → Prop) (Q : V → T → Prop)
(P : T → W → Prop), P ∘ Q ∘ R = (P ∘ Q) ∘ R.
Any help would be extremely appreciated!
Thanks in advance,
~Scott Constable
- [Coq-Club] Prove associativity of composition of relations, scott constable, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Frédéric Blanqui, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, scott constable, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Fabian Kunze, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Cyprien Mangin, 05/11/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Thorsten Altenkirch, 05/12/2016
- Re: [Coq-Club] Prove associativity of composition of relations, John Wiegley, 05/12/2016
- Re: [Coq-Club] Prove associativity of composition of relations, Abhishek Anand, 05/12/2016
