coq-club - Re: [Coq-Club] Suggestions for Proof General?
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Suggestions for Proof General?
  • Date: Fri, 17 Jun 2016 13:38:15 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=stecksoft AT gmail.com; spf=Pass smtp.mailfrom=stecksoft AT gmail.com; spf=None smtp.helo=postmaster AT mail-vk0-f54.google.com
  • Ironport-phdr: 9a23:SucZNRWLdZ7pxo7w4xuKZ7piyJvV8LGtZVwlr6E/grcLSJyIuqrYZhGDt8tkgFKBZ4jH8fUM07OQ6PCxHz1Yqs/Y7jgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2CJVQQz2PkP/tbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN/dwcbsNBzM/dmsx+cej4RLEVE6E4mYWemQQiBtBRQbfukLURJD052HCv/d5kADcdfbqQLs3XTm4pe8/UwPlgyQvLCI0+2LMjcJsyqlcpUTy9FRE34fIbdTNZ7JFdaTHcIZCSA==
Others have asked for a progress indicator, too.
OK, I think these requests should keep me busy!
-- Paul
On Fri, Jun 17, 2016 at 1:34 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
> On 06/17/2016 01:13 PM, Paul A. Steckler wrote:
>> We might be able to do one or more of these, and we should discuss
>> when I'm farther along.
>> The XML protocol returns lists of goals, classified in various ways
>> (shelved, abandoned, background). The window size can be queried, so
>> the way goals are displayed can be cued from that.
>> What types of hypotheses would you like to hide, or would you want
>> that configurable in some way?
>> -- Paul
> Certainly configurable. In some cases, showing hyps that other hyps or the
> conclusion depend on is redundant, because it is trivial for the user to
> figure out their types from their uses. Maybe if those hyps were just
> highlighted at their uses in some way - maybe a particular color to indicate
> that they are hyps and not global constants.
> However, because humans tend not to be as proficient at type inference as
> machines, there's probably some complexity such that merely highlighting a
> hyp at its usage and not dedicating a line to directly showing its type is
> annoying. Maybe by having the mouse hover over the user click on a usage,
> that would bring up a tooltip with its type. And clicking on the usage
> would make the line for that hyp visible.
> Maybe that tooltip could apply to evars as well. And maybe clicking on an
> evar would show its goal.
> On a different front: how about a version of that new colorized progress bar
> that CoqIDE has at the bottom?
> -- Jonathan
