coq-club - Re: [Coq-Club] Suggestions for Proof General?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Suggestions for Proof General?
  • Date: Fri, 17 Jun 2016 13:34:13 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f170.google.com
  • Ironport-phdr: 9a23:bRhQER+LEHzLN/9uRHKM819IXTAuvvDOBiVQ1KB91+scTK2v8tzYMVDF4r011RmSDdSduqoP0rOI+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuSt+U3pz8jrnss7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCmI4HIAUmwQ2j5FAhbI6g2yCpX2tCr5u+5w1QGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
On 06/17/2016 01:13 PM, Paul A. Steckler wrote:
We might be able to do one or more of these, and we should discuss
when I'm farther along.
The XML protocol returns lists of goals, classified in various ways
(shelved, abandoned, background). The window size can be queried, so
the way goals are displayed can be cued from that.
What types of hypotheses would you like to hide, or would you want
that configurable in some way?
-- Paul
Certainly configurable. In some cases, showing hyps that other hyps or the conclusion depend on is redundant, because it is trivial for the user to figure out their types from their uses. Maybe if those hyps were just highlighted at their uses in some way - maybe a particular color to indicate that they are hyps and not global constants.
However, because humans tend not to be as proficient at type inference as machines, there's probably some complexity such that merely highlighting a hyp at its usage and not dedicating a line to directly showing its type is annoying. Maybe by having the mouse hover over the user click on a usage, that would bring up a tooltip with its type. And clicking on the usage would make the line for that hyp visible.
Maybe that tooltip could apply to evars as well. And maybe clicking on an evar would show its goal.
On a different front: how about a version of that new colorized progress bar that CoqIDE has at the bottom?
-- Jonathan
