- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Suggestions for Proof General?
- Date: Thu, 23 Jun 2016 23:44:43 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
- Ironport-phdr: 9a23:oztuuhWfmvAzqdxmi6zPE6CT8rDV8LGtZVwlr6E/grcLSJyIuqrYZhaEt8tkgFKBZ4jH8fUM07OQ6PG4HzRfqs/f+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLshrj0o8KYOlsArQH+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7a3HIYXC00jxxHS1zH8Rf1dpLps27hqfE73zOVa56lBYsoUCivuv84ACTjjz0KYmY0
Hi,
> We frequently have goals where "P" is large. Usually that's an accident
> ;-) but for example, proving a Hoare triple about an interesting piece
> of code can result in a pretty long goal of which only the beginning
> (the expression in head position) is interesting.
> You are of the "strongest postcondition" chapel then. And Thou shall
> Burn in Hell for such perverted practice! :-)
Actually, we're using weakest preconditions. ;)
> Then telescope being yet another set of hypothesis (cf R. Krebbers proof
> mode), they would go in yet another window?
> Leading to something like:
> H1:... scrollable
> H2: ..
> P1
> P2 scrollable
> P3
> P scrollable
Right, the Hoare triple I talked about is just the conclusion in
Robbert's proof mode. So I guess PG has little chance of understanding
that goal anyway.
Doesn't putting all these things into separate buffers waste enormous
amounts of space, i.e. those extra status lines and scrollbars emacs
puts at the bottom of a buffer?
Kind regards,
Ralf
- Re: [Coq-Club] Suggestions for Proof General?, (continued)
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Pierre Courtieu, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, John Wiegley, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Ralf Jung, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/24/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Emilio Jesús Gallego Arias, 06/17/2016
