- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Suggestions for Proof General?
- Date: Thu, 23 Jun 2016 22:27:56 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f54.google.com
- Ironport-phdr: 9a23:v/I1mxGiSCPsWlSOBzUC151GYnF86YWxBRYc798ds5kLTJ75oM2wAkXT6L1XgUPTWs2DsrQf2rKQ6/+rATFIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWD14LviKvqptX6WEZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwuwwZgf8q9tZBXKPmZOx4COUAVHV1e1wysebsrFHoSRaFri8XVXxTmR5VCSDE6gv7V9H/qH2pmPB63XyiPMDsV718cjO/9btqRQKg3D8GOiQj/SfcjdFqkKNWvTquohV+x8jfZ4TDZ6k2Rb/UYd5PHTkJZc1WTSEUR9rkN4Y=
I don't know, I think most of regular users's large goals are of the form
P1 ->
P2 ->
Pn ->
P
and in this case isn't P what people want to see?
Well... At least ssreflect users may want this option set by defaut since P1 is the "active" hypothesis.
P.
2016-06-23 17:54 GMT+02:00 Clément Pit--Claudel <clement.pit AT gmail.com>:
👏 Thanks Pierre!
Should we enable this by default?
On 2016-06-23 11:47, Pierre Courtieu wrote:
> Done in trunk.
> (setq coq-prefer-top-of-conclusion t)
> should do it.
> Best,
> P.
> 2016-06-23 17:04 GMT+02:00 John Wiegley <johnw AT newartisans.com <mailto:johnw AT newartisans.com>>:
> >>>>> Pierre Courtieu <pierre.courtieu AT gmail.com <mailto:pierre.courtieu AT gmail.com>> writes:
> > When the goal is large, PG displays as much as possible of the goal, with an
> > order of precedence: - prefer conclusion over hyps (1) - prefer bottom of
> > the conclusion over its top (2)
> > This is rather empirical setting. (1) is hardly questionable imho, but (2)
> > is indeed arbitrary. I can maybe have an option for (2).
> An option for (2) would be very helpful. I'm working with MIT's Fiat system,
> which involves proofs that refine monadic, non-deterministic blocks "action by
> action", from top to bottom, so knowing the bottom of the conclusion without
> seeing the top is relatively useless.
> Thanks,
> John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
> http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
- Re: [Coq-Club] Suggestions for Proof General?, (continued)
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jason Gross, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Pierre Courtieu, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, John Wiegley, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Ralf Jung, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/24/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Emilio Jesús Gallego Arias, 06/17/2016
