- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Suggestions for Proof General?
- Date: Fri, 17 Jun 2016 22:23:16 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:ntUZIhf9Pa/b5yaqKzPZLZnMlGMj4u6mDksu8pMizoh2WeGdxc6+YR7h7PlgxGXEQZ/co6odzbGG4uaxACddsd6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDjvcyKKFgYzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB04SEx9FBRTy1BDmG9LatiLnuud5kH2ROcDzQLYoHyyj849kTRbpjGEMMDtvozKfsdB5kK8O+EHpnBd42YOBOIw=
On 2016-06-17 19:02, John Wiegley wrote:
>>>>>> Jonathan Leivent
>>>>>> <jonikelee AT gmail.com>
>>>>>> writes:
>> Could PG be made to show multiple complete goals if the goal window is big
>> enough?
> I'd like it if I could just always make sure that the top of the current
> goal
> is brought into view after each command. I find myself manually scrolling
> the
> response window often when large goals are involved.
Please file a bug report: this is already implemented, I think, so you're
most likely running into a bug :)
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] Suggestions for Proof General?, (continued)
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Paul A. Steckler, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/20/2016
- Re: [Coq-Club] Suggestions for Proof General?, John Wiegley, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jason Gross, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Pierre Courtieu, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, John Wiegley, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Ralf Jung, 06/23/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/23/2016
