- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Axioms reported by coqchk
- Date: Fri, 19 Aug 2016 15:12:05 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
- Ironport-phdr: 9a23:CgFnaRCahiFaMHnmdhf5UyQJP3N1i/DPJgcQr6AfoPdwSP79rsbcNUDSrc9gkEXOFd2CrakV0qyM7eu9BCRAuc/H6yFaNsQUFlcssoY/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbtr8FoOatcmrzef6o8SVOFQRwmDjKu4vZFXu9EOK55FQ2dMjYo8KiTLx6kNSfOpXwW46bXmypD3bovmKwZh47i5LsOgg/cMTGY/zfqA/UKAKRG9+azN9t4XXskzIShLK7X8BWE0XlABJCk7L9kLURJD05xH9vOBwwjXSHtf7R7o5Qy/qu6JiSRvpjigDNiUl60nNjcZ6gbhHowisrRZy2ZWSZoXDZ6k2Rb/UYd5PHTkJZc1WTSEUWo4=
On 08/19/2016 02:16 PM, Jacques-Henri Jourdan wrote:
It seems that just importingAlternatively, Program could provide means of importing the base
functionality without needlessly importing modules. What do you think?
But then how different is this from refine ?
From Coq.Program Require Import Syntax.
is enough to make the Program vernacular to work. As far as I see, the above does not import any axioms, contrary to importing Coq.Program.Tactics.
Some remarks:
- Everything in Coq.Program.Syntax and Coq.Program.Basics seems to be very generic and is not specific to Program at all. Why isn't that somewhere in Coq.Prelude?
- When using Program without importing anything, Coq complains with
"Error: Library Coq.Program.Tactics has to be required first."
However, just importing Coq.Program.Syntax is enough. Why is one required to import anything of Program from the standard library to use the Program vernacular?
- Re: [Coq-Club] Axioms reported by coqchk, (continued)
- Re: [Coq-Club] Axioms reported by coqchk, Pierre Courtieu, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Ralf Jung, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jacques-Henri Jourdan, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Guillaume Melquiond, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Matthieu Sozeau, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Pierre-Marie Pédrot, 08/19/2016
- RE: [Coq-Club] Axioms reported by coqchk, Soegtrop, Michael, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Robbert Krebbers, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Ralf Jung, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Robbert Krebbers, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Jonathan Leivent, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Guillaume Melquiond, 08/19/2016
