- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Axioms reported by coqchk
- Date: Fri, 19 Aug 2016 13:54:42 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f45.google.com
- Ironport-phdr: 9a23:aH/hRR1grjx5vWdEsmDT+DRfVm0co7zxezQtwd8ZsegTLvad9pjvdHbS+e9qxAeQG96KsrQe1aGI4+igATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJV8Wz2TtKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduYCgJ45jgsgCGRg+S7FMdVH8Xm1xGGVvr9hb/C7L4rjf6t+dgkBKdL8D/UPhgXD2+865uYBrhlDsOMng+6m6B2Z84t75SvB/0/083+IXTeozAbPc=
Indeed there was a proposal recently to remove axioms from the usual Require Import Program, but
that in turn will force anyone who uses dependent destruction to explicitly Require Import Program.Equality.
It's only Program.Tactics and Program.Wf that are necessary for Program to function correctly (IIRC, for
the default program_simpl tactic and well-founded fixpoint combinators).
-- Matthieu
On Fri, Aug 19, 2016 at 3:47 PM Ralf Jung <jung AT mpi-sws.org> wrote:
Hi,
> On 08/19/2016 03:13 PM, Ralf Jung wrote:
>> However, if "--list-dependencies-of" would take wildcards, like "iris.*"
>> that could work.. oh wait, no. That would also cover all the reexported
>> unused axioms from the standard library, right?
> That was the kind of think I was thinking about. And no, I do not think
> you can access an stdlib axiom via iris qualified names.
Isn't it the case that if I say in iris/prelude/base.v
Require Import Setoid
then I can later access "iris.prelude.Setoid"?
I thought that's what you were referring to when you said that one can
still access non-exported names through their fully qualified name.
However, somehow, it must be clear in the .vo file whether a name is
defined here or whether it is just re-exported -- and then coqchk should
simply check everything that's defined in the modules it gets as
argument, but nothing that's just re-exported. Couldn't that work?
Kind regards,
Ralf
- Re: [Coq-Club] Axioms reported by coqchk, (continued)
- Re: [Coq-Club] Axioms reported by coqchk, Ralf Jung, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jacques-Henri Jourdan, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Beta Ziliani, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Pierre Courtieu, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Guillaume Melquiond, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Matthieu Sozeau, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Pierre-Marie Pédrot, 08/19/2016
- RE: [Coq-Club] Axioms reported by coqchk, Soegtrop, Michael, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Robbert Krebbers, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Ralf Jung, 08/19/2016
